From aos:
...I can tell you that AK4117 works well in hardware mode, without a
microcontroller because I used it in both PPA and Piccolo standalone. You might run into some problems as it seems to behave
sometimes in the ways not in the datasheets, but you shouldn't have trouble to get it working with at least 44/48 kHz but since you
likely want it for USB and possibly CD use, that is all you care anyway. |
But since it's difficult to find this part, maybe we should consider DIR1703E? They have them on hand at digikey.. The only difficulty is finding a datasheet for it...
Edit: No, it's quite easy to find the data sheet for the DIR1703E. I'm an idiot. Anyway, I asked aos about acquiring the AK4117s. He said go to the AKM website. He thought it might be Allied Electronics or All Electronics though.
All American Electronics seems to carry it- but their website says that it is currently down for maintenance, sooo...? No - it's back up. So that's a potential source for the AK4117, which could be nice.
The DIR1703E from TI is a lower jitter part, 75ps versus 200 for the AK4117; so the DIR1703 is a better part, and it is still available from Digikey- though they only have 613 in stock, and it doesn't look like TI is producing them anymore, so...
Another possibility is that AK makes a part that is both a DIR and an ASRC is the ak4122. I haven't finished downloading the datasheet for it yet- but it might work then to replace both the CS8416, a mux, and the ASRC. But I',m talking out of my ass, so.. wait and lets look at the data sheet.
