Frozenhaze
- Apr 15, 2016
Edit: Thanks for reminder, I'll find a more appropriate thread.
Greetings to all audiophiles. I'm new member of the forum. I want to add to the list of cable that produces in my country .. "Final Touch USB Audio". I think it is middle class cable, its price is around $ 100.
I would add my opinion about USB cables, since it raises the debate as to whether there is a difference. Of course there is a difference, but they will hear the system which can transmit the details and differences, which is based in the nuances of sound.
I still can't believe that the USB cable itself makes any noticeable difference nowhere else than in our heads unless there is some serious problems with the construction etc. It simply can't be because it transfers only digital signal data which can tolerate electromagnetic interference quite well. The only problem is that the cable itself might carry some interferering signals from your source and ambient to the amplifier state and that's why some USB cables have a ferrite chokes on them. A high-quality amplifier can handle and filter those unwanted interfering signals quite effectively but the problem is that many inexpensive models doesn't have proper signal filtering duo to cost savings.
Common:
Monoprice (13)
Free cable that came with DAC (10)
Standard printer USB (9)
Cheap USB 3.0 certified cable (1)
Mediabridge 2.0 (1)
USB A male to a USB B male adapter (1)
Specialist:
Belkin Gold (11)
Wireworld Starlight (8)
Supra USB cable (5)
Kimber Kable CU (5)
Cabledyne Reference Silver (5)
Audioquest Diamond (5)
Cardas Clear (4)
Mapleshades Clearlink Plus (3)
Pangea Audio 24 ga. solid silver USB cable (3)
Audioquest Cinnamon (2)
Audioquest Coffee (2)
Furutech GT2 USB cable (2)
Chord USB Silver Plus (2)
DH Labs SilverSonic (2)
Audioquest Cinnamon mod for HUGO (1)
Final Touch Audio USB (1)
Audioquest Forest (1)
Acoustic Revive PL (1)
Acoustic Revive USB-1.0SPS (1)
Audioquest Carbon (1)
Black Cat Silverstar USB cable (1)
Computer Audio Design CAD (1)
Curious usb 280mm Hugo Link (1)
Copartner A to B (1)
Crystal Cable Absolute Dream (1)
Eljah Audio Isolate CU (1)
Guitardave's Pangea (1)
iFi iUSB Power + Gemini (1)
Kimber Kable Silver AG (1)
KingRex uArt S USB Cable (1)
JCAT (1)
Locus Polestar (1)
Lavricables Pure Silver USB cable (Dual headed) (1)
Neo d+ class S (Oyaide) (1)
NuForce Impulse (1)
Oyaide 5s continental (1)
Paul Pang Red Separate USB (1)
Rosewill Goldplated (1)
Shunyata Research Venom USB (1)
Synergistic Research USB Active SE (1)
Tellurium Q Black diamond USB (1)
Tellurium Q Blue USB (1)
Transparent Audio Premium (1)
Tripp Lite w/ Ferrites (1)
Vertere Double D D-Fi V2 (1)
Vivanco USB 2.0 A/B (1)
Whiplash Audio Polestar (1)
Wireworld Silver Starlight (1)
Wireworld Ultraviolet (1)
WyWires USB Silver (1)
Common:
Monoprice (13)
Mediabridge 2.0 (1)
Specialist:
Belkin Gold (12)
Supra USB cable (5)
Kimber Kable CU (5)
Cardas Clear (4)
JCAT (1)
Locus Polestar (1)
NuForce Impulse (1)
DoneCommon:
Monoprice (13)
Mediabridge 2.0 (1)
Specialist:
Belkin Gold (13)
Supra USB cable (5)
Kimber Kable CU (5)
Audioquest Diamond (6)
Cardas Clear (4)
Audioquest Carbon (2)
JCAT (1)
Locus Polestar (1)
NuForce Impulse (1)
WyWires USB Silver (1)did i do this right? notice i added another aq carbon. great cable if you do not dig dbs.
