bigshot
Try going further than three feet from your phone with wired earbuds.
Erm, you just said you didnt say what I said you did, then went ahead and confirmed you were saying exactly what I said you did ... It doesnt make any sense, but its exactly what I said.I did not say that there are 8-10 connectors, what I am saying that if I have 10 Wired Earphones, then I will need 10 or even more Connectors to use them and still Inserting and Pulling them will damage my Phone USB Port. There is no way your DAC can provide high quality sound than using 3.5mm directly.
Yes, it does. Just because there are back up analogue lines in some USB C headphones that are used in some situations, doesnt mean they are always used by any hardware. That line is a failsafe and only used if the phone cant find a USB host/DAC. It will attempt to connect via USB first and only falls back to analogue over USB if one isnt present.Your External DAC or Dongle does not do anything except connecting your 3.5mm Earphones with Phone's USB C Port.
It is easy to understand if there is any fact or iota of truth what these people have been telling you and many others to sell their DAC/Dongles. I have used the Avani DAC and I can safely say that it did not make any impact on sound quality so it is just connector which will connect your 3.5mm earphones with your USB-C Device. If I had not used it, I would be agreed on your theory but sadly that is not correct.It appears you still hold the same misconceptions as you did ages ago, so its best we just leave you to it. If you still dont understand these basics after they were explained to you years ago and are still stubbornly holding onto biases that are not even rooted in reality; there is really nothing anyone can say. You are stubbornly and loudly ill-informed.
More than 1 adapter needed so there is one connected to every 3.5mm wired earphones. 1st thing, I am sure that they will break down more than often and also damage your phone's USB port. 2nd and most important thing, for some reason, if you change your earphones, which we may often do on regular basis, and forget to pick your Dongle, then that earphone will be of no use as you cannot connect and use it with your USB-C only Phone.Erm, you just said you didnt say what I said you did, then went ahead and confirmed you were saying exactly what I said you did ... It doesnt make any sense, but its exactly what I said.
Why would you need more than 1 adapter cable to connect your 10 wired earphones? your phone has the USBC port, you have a USB-C->3.5mm cable and you say youre earphones in this example are 3.5mm. Why would you need any more than 1 USB-C->3.5mm cable? It would also remain plugged into your phone if you wish, with only the 3.5mm jack getting any wear, if you indulged your want to plug a different headphone in every few minutes.
No Sir. I have used the DAC myself and it did absolutely zero in terms of changing the sound quality. It is just these Phone and DAC/Dongle Manufacturers gimmicks to fool people and force them to buy these craps.Ummm, yes. Yes there is.
You dont understand how ANY of this works, do you? Even things as simple as cables you apparently dont understand the operation of.
So you believe in what these people have mentioned and put some paid article? Bluetooth Headphone/Earphone Market by the end of 2019 was US $60 Billions and expected to be more than double by 2026. No wonder these companies have put some article that Bluetooth is this and that and better and best and what not. After all, they are eying big shares in $120 Billons and everyone want the max share. But people who have heard these Bluetooth earphones, they know that they are not even 10% match of the quality of 3.5mm Wired Headsets.It isnt a theory, its the USB C specification you numpty
USB DAC, when connected to your phone, does absolutely nothing except connecting your earphones to Device.No, I believe the USB specification. I have applied it in both hardware and software; it works. a well applied USB dac will easily and measurably outperform the onboard dac built into an SOC and will support modern formats more widely too.
I was expecting at least decent increase in sound quality but I did not see even 1% change in the sound when I used DAC. So forget 10X or 10%, it does nothing except connecting your wired earphones to Phone.It is easy to tell you havent been at this long. No one worth their salt would make ridiculous exaggerated statements like '10x better' 'not even 10% match' If you have experienced 10x improvements ANYWHERE in your audio chain, you are playing at the shallow end.
3.5mm Connector is Worst? I guess these scamsters companies made fool of millions and you are one of them who believe them easily and started singing their tunes that Bluetooth is good and 3.5mm was worst but it was there till 2-3 years ago and still these companies are giving it in their cheap phonesThe rest of your post is 100% irrelevant.
btw, the 3.5mm connector is one of the worst connectors in use in audio. I would be very glad to see the back of it.
Do you have a cell phone? Is a land line better than a cell phone because it doesn't require charging?
audio-vaxxerat least he doesn't hurt someone
Your understanding about USB-C Audio and Dongles/DAC is wrong. You see what these companies want you to see thus speak their language only.Don't waste your time.
He has lost touch with reality. He has no idea how DAC's or USB-C works and still persists in his theories.
I've tried to explain him many times and showed him even proof that his theories aren't true.
Than explain how a DACs works, or how Android handles external DACsYour understanding about USB-C Audio and Dongles/DAC is wrong. You see what these companies want you to see thus speak their language only.
