BaTou069
- Oct 30, 2013
Did some one try the Regen with the LH Labs Geek Out/Pulse? (without LPS)
I sent an email to Matthew of Forza requesting an adapter be made for the Regen. I asked for a male to male usb 'A'>'B'. I will use it with the one he had previously made me for the micro idsd. I will use the new adapter by itself when I connect the Regen to the future idsd pro.
The Audioquest Jitter Bug looks like an interesting device. I already have an ifi ipurifier in line with the Regen. I suppose the Jitter bug might be overkill but at $49.....??
I started using the micro in battery mode with the Regen and improved SQ even more. The Regen rocks!!
EDIT: Kritikal, I just digested what you said about using the Jitter bug. I would get rid of the ForzA adapter and the adapter sent with the Regen and put the Jitter Bug directly between the micro and the Regen............SWEET! I'm going to try that.
No, that is not a good idea. Please do not put anything between your DAC and the REGEN. Signal integrity and impedance match are bed right our the REGEN. Anything else will mess with that.
Thanks for monitoring our ideas and giving us good feedback. I will scrap that Jitter Bug idea.
I will proceed with the Forza made adapter to replace the the stock 'A' to 'B' adapter supplied.
Is it "Mid August" yet?
I am not saying you shouldn't use the Jitterbug--it may prove complementary to the REGEN. I am just saying to be sure not to use it AFTER the REGEN. The REGEN and some short adaptor or really good short USB cable should be things closest to the DAC.
In celebration of that, 150 REGENs are going to the post office tomorrow!
So if your order number is lower than 1915 and you don't get a notice tomorrow, it means you are in the next batch later in the week/following Monday.
Hi Mike, great pic thanks for sharing and I don't mean to break it or anything like that but you might be quite surprised by what's in those neat little $1 USB adapters of yours:
Yes, steel wires of the cheapest kind they could source.
With the LM317, TO-220 rectifiers and 4000uf onboard capacitance, it was certainly designed and constructed to the same standards. (..) Tangent's TREAD power supply measures 0.060mVAC, with the STEPS very slightly better at 0.058mVAC. I confirmed for Colin that (..) the newly constructed miniature MAX with board surgery measured 0.0mVAC on the Fluke.
Hi Alex,
Thanks for the swift reply, it's not very often that you see gear manufacturers take the time to pretty much instantly reply in public threads discussing their equipment so major kudos for that
Right, I didn't know that you do provide them with the unit and I forgot that there are indeed better adapters than the $1 chinese ebay ones. Conductors still aren't quite as thick as decent USB cables and nowhere near as shielded but I'll give you that those adapters are short so it might not matter nearly as much, this said they can put a lot of strain on USB connectors and I did kill a small USB DAC input like this once hooked up onto an ADuM4160 dongle.
I'm no enginner and I do realize that for instance Benchmark claimed that they used a low-noise SMPS in their DAC-2 because it provided higher performance than a LPS, but IME the former always sound more natural and less digitis-ridden than the former. I would love to be proven wrong and will be eagerly looking forward my friend's findings regarding a Wyrd Vs Regen shoot-out for sure.
Noise is one thing, but at the end of the day one of the main factors that would matter the most to SQ would be ripple and these figures seem really really low: http://www.diyforums.org/MiniMAX/MiniMAXhistory3.php
Zero ripple basically, using LM317 as far as I understand. How can it get any better than that? Can a switched mode PS or regulator provide zero ripple?
BTW, great blog you linked here(I spent more time than I would admit reading it ^^) and I see that he mentions WaveIO, which reminds me that it doesn't work with Wyrd. Lucian gave me a technical explanation to it: http://www.head-fi.org/t/724519/schiit-decrapifier-released-usb-power-isolator/390#post_11355378
Would Regen suffer from the same issue?
