mjock3
- Aug 23, 2011
Nice write up in AudioStream. Congrats Alex & John!
Is there anything else I should be placing between my outlet and computer, or outlet and Regen, or Regen and DAC, or DAC and amp, to get the best out of this?
My latest "transportable" rig:
There's room for improvement with the USB A -to- USB Micro B cable that connects the USB Regen to the OPPO HA-2
iPad 3 > CCK > Supra USB 0.7m > UpTone Audio USB Regen powered by 9V Anker Astro Pro LiPo battery > Oppo HA-2 > Sennheiser HD 800
It sounds great at the moment, but it goes against the consensus that you want this connection to be as short as possible. With the USB Regen having "washed" the bits, why get them dirty again?
I've ordered a "solid" adapter and a short cable that looks promising, in case the solid adapter puts to much stress on the connections by nature of the Oppo HA-2 being thinner than the USB Regen. Then again, I could always elevate the HA-2 with some kind of a shim beneath it, I suppose.
I'll be testing both of them to make sure their shields are connected at both ends.
(snip)
To power the USB Regen, you will need a supply that delivers a minimum current of 1 Amp, in the range of 6VDC to 12VDC, as follows:
6V is the lowest you can go, keeps heat inside the Regen to a minimum and it works for DACs that require 5V USB power or DACs that don't, but the Regen might not sound as good as when powered with higher voltages.
7.5V is what the Regen's included SMPS supplies, runs the Regen a little warmer than at lower voltages, works for DACs that require 5V USB power or DACs that don't, and the Regen might sound better than at lower voltages, but not as good as at higher voltages.
9V is as high as you can go if you are using a DAC that requires 5V USB power, works fine with DACs that don't, and the Regen might sound better than at lower voltages, but not as good as at higher voltages.
12V cannot be used with DACs that require 5V USB power, but works fine with DACs that don't, and the Regen might sound better than when it is powered at lower voltages.
Note: My references to how the Regen might sound better when it runs hotter, relate to previous posts in this thread where that was discussed. YMMV and MMMV, too!
Mike
Just read the Regen review on Audiostream and subsequently, the Jitter Bug review. This got me wondering about how it would affect the signal after the Regen, rather than after the source if it was used instead of a USB adapter. It could be perfect to use with the iDSD Micro between the Regen and the Micro, due to the recessed male connection on the DAC, without having to add another link in the chain. I was considering buying a custom adapter from Forza (like Franatic has), but perhaps this would serve a better/dual purpose?
Does anyone have any experience with a Regen and Jitterbug combo?
I'm thinking that for $79AUD shipped, it's certainly worth trying.
I sent an email to Matthew of Forza requesting an adapter be made for the Regen. I asked for a male to male usb 'A'>'B'. I will use it with the one he had previously made me for the micro idsd. I will use the new adapter by itself when I connect the Regen to the future idsd pro.
The Audioquest Jitter Bug looks like an interesting device. I already have an ifi ipurifier in line with the Regen. I suppose the Jitter bug might be overkill but at $49.....??
I started using the micro in battery mode with the Regen and improved SQ even more. The Regen rocks!!
EDIT: Kritikal, I just digested what you said about using the Jitter bug. I would get rid of the ForzA adapter and the adapter sent with the Regen and put the Jitter Bug directly between the micro and the Regen............SWEET! I'm going to try that.
