Patrick82
Banned
- Mar 1, 2003
I would like 192 kHz upsampling with AES/EBU output, does something like that exist?
Originally Posted by Sherwood /img/forum/go_quote.gif What you're looking for is a resampler with AES/EBU output, Patrick. Once you actually perform the Digital to Analog conversion (DAC), you don't need digital outputs any longer. |
Originally Posted by Sherwood /img/forum/go_quote.gif The dCS was a reclocker, and the Cary was a transport. Neither was a proper DAC, like your Benchmark is. What kind of an input do you want? USB? Firewire? Are you going to be using it to play files off your computer? |
Originally Posted by Sherwood /img/forum/go_quote.gif Firewire would give you a few more options, so if your laptop can handle it you might consider getting a firewire PCMCIA card. If you do that, take a look at the MOTU Traveller Mk. 3 and the Weiss Vesta |
Originally Posted by obobskivich /img/forum/go_quote.gif what about that Space Audio Tech thing that does 26-bit? I'm not actually trying to make a joke here, I just forget what it was actually called it resamples to like 26-bit/22.5mhz (yes, mhz) and then drives analog out (so no AES afaik, but its putting the data to a level the DAC1 couldn't use) |
Originally Posted by obobskivich /img/forum/go_quote.gif as far as 192khz over a single AES cable, can the DAC1 even support that kind of data rate? (I'm curious) |
Originally Posted by gregorio /img/forum/go_quote.gif "It worked when I tried it, I compared 96kHz and 192kHz, there was a huge difference. " Then there is a serious problem with your playback chain!! |
Originally Posted by gregorio /img/forum/go_quote.gif " Why on earth do you think that upsampling to 96kFs/s or 192, presumably from a CD can possibly improve anything? You think that maybe the potential artefacts caused by 16bit/44.1kFs/s are going to be magically removed by upsampling? I'm not trying to be insulting, I am genuinely interested in why you feel you will get a better result by upsampling or using a larger bit depth. |
Originally Posted by gregorio /img/forum/go_quote.gif Also, why AES/EBU, rather than optical or SPDIF? Cheers, G |
