Patrick82
Banned
- Mar 1, 2003
Are you saying there are many Universes? In that case anything is possible: a way to visualise 10 dimensions - Science Forums, The Original
If you build a house using bricks (1s) and holes (0s) the building will collapse if the hole is in the wrong position. Also, if the bricks are vibrating from an earthquake it will be hard to sleep. But to some people it does not matter, they are still 1s and 0s (what does little jitter do?). But to the person lying under the collapsed building it matters.
I have found that Magix levitation feet reduces a lot of jitter which makes it sound smoother. I could not hear a difference between SACD and CD upsampled to 192kHz when I had Magix under both transports.
I have tried having only one conductor connected, I got no signal. I tried with AC power and headphones too! I have also tried connecting the wires together while touching the diaphrams of K1000, it gave off sound but I saw smoke on the surface of K1000 diaphrams, it also burned a hole through them, but I fixed it with scotch tape.
It is true for analog signals, the shorter the better! But for AC power I have found that using a vibration dampening power cable reduces the AC noise and gives better sound after adding it to the path. Other power cables I have tried worsens the sound. Genesis power cable is the only one that improves the sound even after daisy chaining 3 of them together.
Have ears been used during the testing?
Incomplete physical laws are not the correct laws, they are the wrong laws.
If it sounds more like real life is it an error?
I experiment for myself instead of read. I haven't read a book in my life!
Recorded music sounds veiled and muddy, I stopped listening years ago to classical "Reference Recordings". I only listen to trance music with different layers pasted on top of each other. It demands more from the system to output the whole music than to record each sound individually.
Everything makes a difference. If you look at the sky you won't see that the aliens are looking back at you wondering why you are looking at them.
Originally Posted by gregorio /img/forum/go_quote.gif Sadly Patrick much of what you assert cannot be possible in this universe. |
Originally Posted by gregorio /img/forum/go_quote.gif What goes through an SPDIF or lightpipe is identical. SPDIF and AES/EBU are for all practical puposes identical too. It's all 0s and 1s, the quality of those 0s and 1s is utterly irrelevant to audio quality. If you can hear a difference there must be a fault with the cables or your system. This isn't an opinion, it's simple fact. |
Originally Posted by gregorio /img/forum/go_quote.gif XLR has 3 connectors, 1 ground, 2 & 3 carring the same digital signal but one of them out of phase, purely for common mode rejection. RCA (SPDIF) has two connectors, a ground and the digital signal. |
Originally Posted by gregorio /img/forum/go_quote.gif BTW, daisy chaining cables is never a good idea as the connections can only degrade the signal. |
Originally Posted by gregorio /img/forum/go_quote.gif Upsampling to 192kFs/s cannot make a difference. Anything lost during the creation of a 44.1kFs/s product cannot be restored by resampling at a higher rate. It's gone, forever, it isn't there anymore and it can't be put back. This really is basic audio theory, taught to every first year audio student everywhere in the world. This theory has been tried, tested, proven and implimented for more than 25 years. |
Originally Posted by gregorio /img/forum/go_quote.gif If you are hearing a positive difference when upsampling there must be a fault with your system or your ears, or you must be living in a universe with a different set of physical laws!! |
Originally Posted by gregorio /img/forum/go_quote.gif Of course, it is entirely possible to hear a negative effect of upsampling, two or four times the data rate to transfer and process is likely to cause considerably more errors. |
Originally Posted by gregorio /img/forum/go_quote.gif I know you are going to fight against what I've written here because it is a bitter pill to swallow when you've been a victim of marketing hype. |
Originally Posted by gregorio /img/forum/go_quote.gif Let me put it this way, I've worked in Abbey Road Studios, Air Lyndhurst, The Hit Factory and several other highly specified (and respected/famous) recording studios around the world. None of them spend more than a few bucks per meter for cabling. Go look up the cost of fully screened Klotz or Van Damme cable. I'm afraid if you're spending more than this you have been done. Unless of course you feel that spending 1000 times too much on cabling has actually made your bedroom sound better than Abbey Road Studios? |
Originally Posted by gregorio /img/forum/go_quote.gif I'm not having a go at you personally, I'm just really annoyed that companies are allowed to mis-lead the consumer so much and that it's not against the law. Sure the specs look better but it doesn't make any difference. |
