Shanling DAP like M8, new M6 or M6 AKM version, Ifi dongle like Gold Bar and Chord Mojo OG are warm sounding.Eartips the included Xelastec SS seal very well for me so not looking around much ( will try crystal tws tips if I can find them cause not available locally)
on the dongle/dap recommendations yeah I think I should’ve explained more.I believe in synergy so I do think there will be gears at every price point that work better with them than the others.
My main use case is from streaming Apple Music. I don’t have an offline library. I would like a dongle/dap that can work well with AM and that can make the mids of mk2 a bit better and thicker.( a slight mid-bass boost would be good too ).
In desktop setup getting R2R with tube but not suitable for IEM or discreet amp is best way to bring warmth and cut down peaks in treble. Though non are cheap.
Don't be afraid to try out some EQ for mid bass
Have heard good thing about Hiby R2R DAPs but don't buy blind and see if you can get a trial. It may be warm however I do worry as these cheap R2R DAPs may be warm but at the same time can sound bright. I personally don't like RU6 although many called it as warm and all but I never found it to be warm sounding and it was bright as well.
