NickleCo
Previously known as DatDudeNic
- Apr 14, 2016
Has anyone tried if there are any sonic variations between the hk special edition + and the regular/international version?
OK but which eartip is that? Personally I like Azla.What eartips people use here to boost the sub-bass presence of the 3DT?
Until now, this is the only ear tips that make whole sound super open and sub bass both rumbly and well separated from mid-high bass. Quite an eye-opener
I confirm that 3DT are VERY capricious about eartips.
I use this eartips mostly with multi-BA iem but it seem 3DT act like a multi-BA due to the drivers being tubed.
More details on the tips please. I use BGVP A07 and Philips cheap earphone tips (she2405, she3555). Philips tips are outstanding and comfortable and has boost in Sunday as well.What eartips people use here to boost the sub-bass presence of the 3DT?
Unfortunately these are random large wide bore eartips i have lying around...they are very cheap. The silicone is thin and soft so it dont create discomfort from pressure. They are very similar to JCV SPIRAL DOT eartips with softer dome. It doesnt seal the 3DT nozzle perfectly which can seem scary but the result is great. I think all DD are already tuned without the need of eartips to extend bass response.OK but which eartip is that? Personally I like Azla.
Bon Jour Mon Ami. For me, with the 3DT it's Tennmak Strong Foam all the way. They seal great with their slow rebound, don't muddy the bass or clip the highs and don't rip & tear like comply. They fit lit foams bu sound like silicone and have a medium large bore that works extremely well with the 3DT. $7 for 6 pair is worth rolling the dice.What eartips people use here to boost the sub-bass presence of the 3DT?
You get an A!Unfortunately these are random large wide bore eartips i have lying around...they are very cheap. The silicone is thin and soft so it dont create discomfort from pressure. They are very similar to JCV SPIRAL DOT eartips with softer dome. It doesnt seal the 3DT nozzle perfectly which can seem scary but the result is great. I think all DD are already tuned without the need of eartips to extend bass response.
Which size are you using? 4.5mm or 4.9mm?Bon Jour Mon Ami. For me, with the 3DT it's Tennmak Strong Foam all the way. They seal great with their slow rebound, don't muddy the bass or clip the highs and don't rip & tear like comply. They fit lit foams bu sound like silicone and have a medium large bore that works extremely well with the 3DT. $7 for 6 pair is worth rolling the dice.
I'm using the 4.5 and they work with all my universals.Which size are you using? 4.5mm or 4.9mm?
Your not the first person to embrace the stock tips.I may be missing something with the tip rolling concept. I've tried Azla EarfitLight Shorts and Xelastics, and it is clear to me that the stock 3DT tips are far superior. Better bass depth and control, better tonal balance, and more realism in the soundstage. Honestly I can't get over how perfectly the stock tips perform.
I have a few foam tips to try, but usually I find they dampen out the bass a bit and it loses some texture. Honestly, I don't feel that the 3DTs can afford to lose and bass performance, since that's not their strong suit to begin with. So for me, it's the stock tips all the way.
I also like SpinFit CP100, like the stock silicon they are soft which is great for SQ and comfort factor. Tennmak foams work ok, but I find they muffle the upper mids/treble a bit much.I may be missing something with the tip rolling concept. I've tried Azla EarfitLight Shorts and Xelastics, and it is clear to me that the stock 3DT tips are far superior. Better bass depth and control, better tonal balance, and more realism in the soundstage. Honestly I can't get over how perfectly the stock tips perform.
