329161
- May 5, 2012
I have my DXP up for sale in the forums here. Used it once. Sound signature is not to my liking. Sydney pickup only.
Hi all. I've been a proud owner of the DXP for a few months now. However, the low quality of the leatherette ear pads are starting to show. It's starting to "harden" and there are visible small cracks if I look carefully enough. This translates to an increasingly uncomfortable listening experience. Does anyone have any solutions to this? I'm not sure there are any alternate ear pads that are compatible with the DXP currently.
I had the same issues with stock pads on the HFI 680's, and am very happy with these replacements, nice and soft = much better quality than stock.
Gave some sets to 2 other owners and they are also very happy with them.
I assume the housing on the DXP is similar so these should work .
Worth a try and best part is they are relatively low cost and near identical dimensions
https://www.ebay.com/itm/Replacemen...256907?hash=item28371bbe4b:g:0TYAAOSwXetZO1Zc
Seller is good and tends to ship/arrive pretty fast compared to most
680 housings are slightly oval , the pads adjust to that perfectly.
Comparing the cup construction carefully to your pics of the DXP the dimensions appear similar.
I managed finding a set of aftermarket MSR7 fabric pads which perfectly matching the stock pads in both size and shape. As the inward facing sides of the fabric pads are still pleather, it only affect the frequency response slightly. By playing a frequency sweep tone I detect roughly +0.5db between 4kHz to 7kHz range, which actually make the FR a bit more balance.
The fabric pads make the Signature Pro more comfortable to wear. Unfortunately the pads are only available from a shop on Taobao.
So this might be even better (genuine leather):
https://www.ebay.com/itm/Genuine-Le...-Headphones-/183252594850?hash=item2aaab4b0a2
and some higher spec ?
https://dekoniaudio.com/filter/?product_cat=audio-technica+ath-msr7&product_cat=audio-technica+ath-msr7
will probably try one of these
I have bought and tried pleather pads similar to these. They have smaller opening and made the sound stage more congested front to rear. I don't like them but you may tried
Dekoni pads are definitely NO! The inward facing sides of Dekoni pads are flat surface instead of curve surface, they will completely block the S-logic vents on the baffle and make weird sound when you wear the headphones.
Exactly my thoughts ..It is strange Ultrasone have opted to provide such low quality pads for such a premium product. DJ headphones should be made with long lasting comfort in mind. The pads on my Pro 900 were far more comfortable and much longer lasting, as each set can last up to up 3-4 years depending on your usage. Really hoping they come out with official replacement pads, or at least a premium upgrade for those of us who already own the DXP and would like a better alternative.
