Do you think this jmoney pads works with my Ultrasone hfi 680?
Ultrasone Pro 900 (J$ Pads + Blue Dragon V3) Review
- Thread starter colmustard
jronan2
- Jan 4, 2011
Did you guys use v3 of the J$ pads?
Nachkebia
- Dec 26, 2009
Mine is definitely not v3, its either v1 or v2.
Nachkebia
- Dec 26, 2009
Okay, I just received pair of V3 denon pads and a pair of beyer pads. But guess what? I am not even going to try them. The leather is soft and it is much muuuch more thinner than the denon pads I have, which means they will have less soundstage and isolation will not be as good.
jronan2
- Jan 4, 2011
Not going to try which ones? And did anyone try the v3 J$ with the Pro 900. I just want to know how much bass punch you lose with the mod.
Dougeefresh
- Jan 2, 2011
Which Beyer pads are these? For 770 or 880/990? I am about to do the same thing. Impressions?
Leander7777
- Dec 10, 2010
@Nachkebia: Could you please tell me which pads are the ones that give you the best soundstage, as the increase in soundstage is my main incentive for buying J$ pads.
colmustard
- Dec 7, 2010
I used the v3 in my review,
jronan2
- Jan 4, 2011
Did the v3 pads reduce the bass at all? Did it do anything to the highs?
colmustard
- Dec 7, 2010
Edit:
In short the bass is tightened a little but still has excellent impact, this is more because your ears arn't pressed up against the driver plates anymore. The highs gain a little bit more detail and sharpness because the leather doesn't leak anything, so if you think that they sound sibilant with the stock pads then they will sound more sibilant with the J$ pads. I personally don't think they are sibilant at all. The mids are the greatest improvement though, as they are definitely more pronounced now.
Edit:
jronan2
- Jan 4, 2011
I read the review when it was written
colmustard
- Dec 7, 2010
I just edited my above post, sorry about that.
jronan2
- Jan 4, 2011
Thanks buddy So i guess the hot glue is holding up well? And have you decided if you will try a different cable ( blue dragon or such)?
I think one of my buddies is trying the beyer velours on the Pro 900. I want to hear those impressions also before I decide what to do. But no doubt I will change the pads to something, probably the v3 J$'s.
colmustard
- Dec 7, 2010
The hot glue is working great, although it makes it a little hard to swivel the pad into place. You really gotta put a good amount of force into that part.
The dt velour pads would be a perfect match for the pro 900 in my opinion, let me know how that works out. Also I will be getting the 5 ft blue dragon cable as soon as I get a few more paychecks, I'll be sure to update this review with my impressions
jronan2
- Jan 4, 2011
I don't know which route I'm going to go yet, I have a new amp coming soon so I will be busy with that when i have free time. I'm just asking around now so when i do decide to mod the pads I know exactly what i want. I really want to try the J$'s because i already know how the beyer pads feel (amazing), and I want to get idea if i would like them with my D7000. I don't really care whether I go with either the beyer velour or denon leather, i just really need to change these pads so I can wear them without getting annoyed and uncomfortable after a half hour. Can't wait to hear the impressions of the blue dragon, which I would assume will be a good review since you can quickly change wires while listening to get a very accurate opinion going.
