theres no material on the inner ring, so would i have to cut out my own piece for somewhere and sew it on?
There is a plastic lip on the inside that slides into the ridges on the hfi580/680/780
Yea. That cloth/foam bit comes included
That's the main reason I don't have them right now. The placement of S logic is too damn finicky. If I own a headphone, I wanna wear them where they make sense, not some in some weird way to get them to sound proper. Last time I had them, it was incredibly annoying to get them to sound right, and not comfortable in that way.
I find the Pro 900 very comfy. I just don't like having to 'think' about placement. I wear the headphones a certain way and it's by instinct. If I have to worry about losing SQ due to S Logic... well, I rather avoid that issue altogether by not having them at all.
I seem to be having a little trouble getting the right sound; the bass isn't harder than the DT770/80 and the sibilance is quite high. Is there a fit guide around for the S-Logic technology used in the PRO 900?
