Please check my edit. Can get v200 upgraded with 24/96 USB input.
I never tested this product and really would like to know how much of the v800 it's in there
USB usually requiers some kind of digital interface to clean up things signal side and /or allow fully fledged 24/192 rez. This means more money into the rig where just buying a new soundcard with coax output would be cleaner. Of course, for Mac based rigs this is not quite an option... If your music files are Red Book only the resolution is a non issue with v200 stock
There is no bad or good with USB... just decisions and paths to follow. Coaxial seems to me the simplest, most effective and inexpensive solution to sending audio to a DAC. All DACs are not made thesame though and hence so much discussion around these matters, some reclock just nice with the interface others not so quite much. Personally, I've seen measured differencies with, namely jitter, but I cannot hear those differences.
About these Edition 8s, they seem to ring all the right bells here: easy to drive, closed, portable. I'm a bit like Skylab has already posted. It's just that I thought I was over spending big money on gear after all these years :\
