uglysteve
- May 9, 2011
I believe super expensive cables are a placebo. They do look super cool though.
I just ordered a pair of heir 5.0s with the Magnus cable so I can test it out with the cable from my 3.ai.
I returned the UE900 to the Apple Store after a few weeks mostly because of the lack of bass (with the tips I had) and isolation needed in a semi-noisy semi-tractor-trailer environment. I didn't have the right tips and didn't know if I'd fine the right ones. What I liked about the UE900 was its tone color. I don't know if a graph would show that particular quality.
I recently returned the Earsonic SM64 mostly because it sounded a little hollow in the mid vocal range. It's not a deficiency of the SM64, it's simply a consequence of coming from the Shure SE535. I didn't want to take a backwards step on any level whatsoever. The SM64 actually seemed more mid forward (in my setup), but nevertheless appeared to lack midrange body. I don't recall thinking that about the UE900. I remember thinking the UE900 sounded a little thin at first, but was at least warm in the lower mids. The thinnest went away when I removed the recessed adapter plug I was using. It also didn't seem to scale up very much.
I think the process of looking for my sound involves hardware/software (source) as well as the earphone itself (for the right synergy). My next setup has to outperform the T Mo' Galaxy S2/SE535 combo. Two much maligned units that (for me) work well together even though separately, I agree with the critics. The 535 come off as an upside-down U-shaped souuding earphone connected to an Apple source. The Galaxy S2 is a high impedance disaster of a source with most headphones.
I'm not a slave to however the software player is set immediately after downloading it (or the way it comes on the Apple DAP). I believe in finding the right software player and turning up the bass and treble. On my Galaxy S1, I have Voodoo bass turned up to the max in sub-bass mode. Then I turn the software player's bass all the way up as well (Poweramp and Maven). The result is bass on my mid-centric earphones. It's not stupendous bass, but it's bass with good mids (and passable treble). The bass from the Shure E5/ Galaxy S1 combo exceeds any (and everything) I can achieve with my iPod Touch 3G/Sennhieser IE8 combo using whatever software (EQu, Equalizer, Accudio, and the rest). BTW, the best third-party music player for iPhone/iPod/iPads is Bongiovi DPS. But there too, you have to tinker with the settings.
I don't know if it's possible to have it all in spades (bass, mids, treble-- with a wide and deep soundstage--with super separation), but the journey continues.
Have you ever tried Neutron Music Player for your Galaxy? I find it amazing. The developer says it's made for audiophiles and has a lot of sound adjustment that will keep you busy for a long time. Really impressive for a cell software. Comparing it to Poweramp the sound is crispy clear... Cheers.
I think if you add AMPs and ALO 18AWG Pure Cryo or CXS cable in chain then any IEMs can sound more fuller with better bass response.
