ShadowVlican
- Nov 14, 2006
you must do 44.1kHz DTS in order to know if it is bit-perfect
afaik there is no 44.1kHz AC3..... AC3/DTS are usually 48kHz and even my crap onboard S/PDIF can passthrough those
Originally Posted by humanflyz /img/forum/go_quote.gif It is bit perfect, I did the whole AC3/DTS passthrough test, and plus the Lavry tells you what bit-rate the transport is putting out. If you are not getting bit-perfect output, it's because you are not configuring your software correctly. |
