Kepller
- Dec 23, 2013
Thanks. I'm concerned that adaptors will degrade the audio quality. Do you have adaptors to recommend? Unfortunately I've already purchased the Shanling UA2 plus. So it is either terminating the wire and risk oxidation of the wire or use adaptors... Or stick with 3.5mm.. Do you guys not make a usb c dac with equal quality for the unbalanced 3.5mm output?Correct, the Balanced output is the one using both amps and is superior to 3.5mm port.
This is standard for Balanced outputs.
If you have cable with 2.5mm and don't want to use adapter to 4.4 or get new cable, we can recommend to look for the older UA2, which had 2.5mm output.
