BrianDonegan
MOT: Twisted Pair Audio
- Sep 1, 2006
Ivy manual is now posted:
http://www.twistedpearaudio.com/docs...manual_2.0.pdf
Originally Posted by penger /img/forum/go_quote.gif So just to clarify, you need 3 IVY boards to have both SE and Balanced outputs? |
Originally Posted by BrianDonegan /img/forum/go_quote.gif Ivy manual is now posted: http://www.twistedpearaudio.com/docs...manual_2.0.pdf |
Originally Posted by mwofsi /img/forum/go_quote.gif Hello Brian and Russ. What's going on in the diagram on page 8 of the pdf manual? It shows a Ballsie going to two IVYs but the IVYs seem to me to be completly bypassed? They are labelled "Normally Configured MONO IVYs" |
Originally Posted by sleepy dan /img/forum/go_quote.gif Hello Russ, Do you find the Opus sounds better with the IVY, compared to running it's outputs direct? I'm simply curious, because as you know the IVY will present a more difficult load (although still within spec) to the Opus compared to the input Z of a typical pre-amp. Usually if a voltage follower sounds better it's regarded as due to its presenting an easier load to the source. Cheers, Dan |
