pabbi1
Cavalli Audio Spiritual Advisor
- Jan 12, 2004
You can definitely stack them - and IIRC, there is some benefit in reducing stray voltage in doing it that way. I had a config like that, and it was just fine.
Originally Posted by pabbi1 /img/forum/go_quote.gif You can definitely stack them - and IIRC, there is some benefit in reducing stray voltage in doing it that way. I had a config like that, and it was just fine. |
I just spent the day laying out my build and I'm in a bit of a pickle with the power section. |
Originally Posted by BrianDonegan /img/forum/go_quote.gif You could also stack both PSUs and place their inputs right next to the trafos. |
Thanks for the suggestion Brian, that was my first inclination, I just thought it would affect the performance of the heatsinks. |
Originally Posted by Ech0 /img/forum/go_quote.gif @ dgbiker1 Is the shielding recommended / required in this build? I hadn't planned on doing this, but, certainly can change if need be. |
Originally Posted by Russ White /img/forum/go_quote.gif dgbiker1, Excellent work! Please let me know what you think of that combo. Cheers! Russ |
Originally Posted by Ech0 /img/forum/go_quote.gif @ dgbiker1 Very neat work & a good shot of the wiring. Well done! Is the shielding recommended / required in this build? I hadn't planned on doing this, but, certainly can change if need be. |
Originally Posted by dgbiker1 I have a microcontroller that will operate a servo to open up a 7" square in the top over the boards, all you'll see are the three boards over the silver plate with aluminum mesh around the sides, a red glow under each board, and white spotlights lighting each board. |
