Fixed.
To run a DL-103 at it's best you really need to use a transformer based pre pre amp. Not to cause a row or upset anyone. It'll work but it'll be a low level and comparatively noisy (~2/3 dB). Shame because the arm/cart is a decent match but like I said you really need to add in the cost of a transformer based (or v. dear int. unit maybe) to make the whole thing worthwhile.
It is strange that although you can now buy a half decent anything else in the audio chain for as little as $100 no one has ever produced a turntable that has been really recomendable at less than the Rega 2/3 or more recently the Technics1200. Been the same for over 30 years.
Never heard that one but there is always a lot of debate around the DL-103
. I use one at the moment with a modded Vestax / RB250 into a Naim 32 with the K board which was originally designed for an '80s Linn MC of Supex provenance. It's a lot of musicality for not much money which ever way you look at it and less of a liability if a child gets near it.
I think step up transformers seem to be more popular in the USA than in the UK as you are of course adding an extra potential load of mains noise into the signal path. Perhaps the mains is quieter in USA? if you live far away enough from an industrial zone.
I don't think it's that strange that nobody makes a decent turntable for 100USD considering what a niche market vinyl is these days. Turntables require decent materials and skilled artisan levels workmanship which was never cheap or else serious design and high precision engineering to work on an industrial scale. Technics were the only company that really got the latter category right and you can still pick up the SL-BD20 for around 150USD if you hunt around. The SL1200 is so worth the extra though.
I guess the Rega P(lannar) 2/3 wasn't that much more than 100USD back in the day which makes the Technics an inflation beating bargain too.
To the OP some reviews here
http://www.tnt-audio.com/sorgenti/technics_sl1200_e.html
http://www.tnt-audio.com/sorgenti/denon-dl103_e.html
http://www.tnt-audio.com/ampli/3_phono_preamps_e.html
The Audio Technica AT0C9 would be the next step up from a Denon which might be a better more "source first" investment than more electronics. http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=ATC01&Category_Code=XMAS
