Head_case
- Dec 9, 2009
The past two months, I use the TTVJ Milletts Hybrid for mostly classical music.
Bear in mind though, classical music for me = string quartets and chamber music. I use Sennheiser HD25 (Mk IIs) and Ultrasone Pro 900s and Grado 125s. The TTVJ opens up the soundstage of all 3. I'm finding that it is not such a desirable feature for the Ultrasone Pro 900s, which are already very expansive (Surround sound logic) in terms of soundstaging. The TTVJ + Ultrasone combination make me feel like chamber music has multipled into an orchestra. If you like orchestral music, then this will be a good thing; better instrument separation. You can hear the detail in arching and bowing between first and second violins particularly in players who are not tonally sealed.
With the Senns, the TTVJ opens up the HD25 (Mk IIs) a lot! The HD25s don't need amp'g, but o anyone who complains that the HD25's lack soundstage or are "too dark", they would be very impressed at what the TTVJ does to them. Unfortunately I'm finding the Grados too painful and bright compared to the closed back headphones at the moment. There are times I like Grados, but not when I'm travelling. These are the last headphones on earth I'd want to go with me. I'd get pummelled for annoying my fellow passengers whilst stranded.
Not so much 'mid-range' as opposed to bringing out the warmth of a recording. I listen to some very lean violin string quartets (the Taneyev Quartet, 1970's-80's recordings). On the TTVJ, these are just superbly resonant and warm. The sound quality from my headphones with the TTVJ is superior to the detail I can pull from my hi-fi!~!
The quibbles now: slight hiss, which I'm noticing is definitely there. The battery life however is phenomenal. I got stuck under volcanic ash skies this week and trapped waiting for a 12 hour ferry. The TTVJ battery life is going into its second week without a recharge. Just incredible.
