TTPOD T2 Hybrid iems
Dec 17, 2014 at 12:09 AM Post #20 of 1,206
sorry I didn't understand
can you explained?
Well, we (or at least I) don't understand the reason for your post. It almost seems as though you think that I am against the t2 hype or something (I'm not, and not sure how you might have thought so). Anyway, no worries.
Dec 17, 2014 at 12:20 AM Post #23 of 1,206
sorry mate It's my bad.. :blush:
No problem! The funny thing is that I want to NOT get sucked into the T2 hype, but the force seems strong with them... if they can deliver quality hybrid (biocellulose even!) SQ for only $99, then they will have a major hit on their hands. And even though I'm not really into blingy looking iems, those look pretty darned cool!
Edit: not sure about "biocellulose", so crossing that out (but it doesn't matter).
Dec 17, 2014 at 12:23 AM Post #24 of 1,206
I hope I'would ot upset or offense anyone with my comment earlier.. sorry :blush:
can't wait to try the T2
I've owned T1 before and quite like it
hopefully T2 will give better performance
No worries, we are all friends here mate, just hard to convey intent across message posts sometimes :)  I have always wanted to try a hybrid and 99 dollars is bonkers. I hope they don't go MOAR BASSS
Dec 17, 2014 at 12:41 AM Post #26 of 1,206
- TTPOD T2, will be released sometime in January
- All 4 color combos will be available during initial release
- Cables are non-detachable
- Triple driver hybrid
- And the best part - price is about $99, available from Penonaudio!!!
Penon is a bit pricer than other stores so it might be even cheaper than that.
Dec 17, 2014 at 1:01 AM Post #27 of 1,206
thx mate :blush:
yeah I feel the same.. a 10mm driver for bass is massive :scream:
Get the resistance right and tuned to compliment the two ba drivers and you will have a sound that extends into sub bass and beyond. I always wondered why the norm on hybrids was becoming a 8 mm driver, which left me wishing for more sub bass, especially with the altone 200 and dgs100
Dec 17, 2014 at 4:21 AM Post #29 of 1,206
Dec 17, 2014 at 4:26 AM Post #30 of 1,206
Oooh i do wish this is the case with the T2, I love me sub bass a lot more than mid bass!
Had the T1E and really liked its presentation across the whole frequency range but unfortunately had that driver loose/buzzing issue after a short while.
Heres to hoping these are more durable! :-)
