I read some your reviews and they are great and detailed, I like them.I use a PC and then transfer to my phone to post but that is only because I cannot remember my login for Head-fi and I use biometrics to login on my phone. In any case, if I insert pictures, the likelihood is that they are on my phone.
TRI earphone impressions - I4 and I3, Starlight, NEW Starsea
ChrisOc
Thank you, very kind of you.I read some your reviews and they are great and detailed, I like them.
The 828 Big Sale of KBEAR Official Store is holding now, you can get your i3 pro and Grace-S at the lowest price in a year.
ChrisOc
TRI i3 swansong
Before (most) folks start receiving their I3s, can anyone (or everyone) suggest a track for us all to listen to on our original I3s?
Hopefully a track on which the I3s shine.
This is my contribution, the Godfather Ochestral suite live recording:
Listen to the timbral accuracy, hiw natural those instruments sound, the dynamism, soft to loud and the expanse of the stage. Do you feel the depth of that sub-bass?
I am looking forward to hearing your choice for the original I3s' swansong.
Upgraded my mobile DAP from a Sony ZX507 to a Lotoo PAW Gold Touch and i can now get the full range out of the Starlights outside of the house. The Sony was decent but even at max volume uncapped, just not enough. Sound is a huge improvement between DAP's also. The Starlight is now my only wired IEM and will stay this way until they break down, which hopefully isnt for a while Mobile happiness!
starlight is really greedy,ZX507 can't satisfy it.Upgraded my mobile DAP from a Sony ZX507 to a Lotoo PAW Gold Touch and i can now get the full range out of the Starlights outside of the house. The Sony was decent but even at max volume uncapped, just not enough. Sound is a huge improvement between DAP's also. The Starlight is now my only wired IEM and will stay this way until they break down, which hopefully isnt for a while Mobile happiness!
RikudouGoku
Member of the Trade: RikuBuds
Btw, anyone know if the stock cable for the I3 Pro is this cable:
https://www.aliexpress.com/item/4000938874310.html
It does look like it to me at least.
Maybe @WendyLi can confirm/deny that.
- Mar 7, 2007
And if so @WendyLi, can we order with the 4.4mm jack?Btw, anyone know if the stock cable for the I3 Pro is this cable:
The listing only has 3.5.
Is there any point asking the KBEAR store if the 4.4 can be substituted instead of 3.5?
Many thanks!
I am sorry that we don't have the original cable with 4.4 jack for now. My collleagues who designed i3 pro told us that Grace-S can be our official upgraded cable.And if so @WendyLi, can we order with the 4.4mm jack?
Many thanks!
If you guys really like the original cable of i3 pro, I will tell my colleagues about it.
No, this is not the same cable and not the same cable base, The cable with i3 pro is customized.Btw, anyone know if the stock cable for the I3 Pro is this cable:
Is there any problems with the cable?
Are you going to release some review?thank you guys, Maybe I know how to do
Looking forward to your article.
RikudouGoku
No problems. But just curious if it was that cable. I could have added it into my cable database otherwiseNo, this is not the same cable and not the same cable base, The cable with i3 pro is customized.
Chris always releases the best reviews haha ~I read some your reviews and they are great and detailed, I like them
- Mar 7, 2007
Only that I never use 3.5mm and would much prefer to buy the i3pro with a 4.4mm cable.No, this is not the same cable and not the same cable base, The cable with i3 pro is customized.
It annoys me that I am collecting (and paying for!) so many 3.5mm cables that will never get used.
I see some other companies are now offering iem's with options which include a stock cable, or alternatively, no cable at all (at a small reduction in price) allowing the customer a little extra budget to put towards a cable which they actually want.
Or simply a choice of stock cable terminations to choose between as is common now.
ChrisOc
