lee730
- Jan 9, 2011
I did notice fitting was a problem with the 1+2, the Comply tips I am using are fine, I can felt when I take them off from my ears, the isolation wasn't that good, maybe I should try some longer tips next.
I wonder if its seal related? Sounds like you are getting a bad seal. Or a defective pair? Never heard them as congested or a small sound staging? The AK120 S mod pairs really well on the 1Plus2. If you are using the silver cable on it I suggest the Studio V 3rd ANV.
