It's true about members in the thread not tolerating criticism about the VC/VO. Most of the time, dissatisfied customers are told to forward the complaints directly to Zach/Bevin instead of publicly, which is fair because they actually have great customer service and are pretty accommodating. Because they are a small business, users are very protective of them. That being said, I'm surprised to find the VC in this thread. I think it's a superior headphone to the VO, especially with the mids.ZMF Verite open and closed, they're veiled in the mids, don't scale regardless of amp and dac, can't do a proper stereo image, very disappointing low end for the closed one and many caveats on using them. Good for mid-fi but doesn't cut the mustard for high end. Nice wood, overpriced and average sound, beryllium marketing. Hideous practice needing to buy 500$ worth of pads to find the goldilocks one, maybe and then you forget which is which since they're not marked. As disappointing as the Empyrean.
All in all the expectations were quite high based on the overwhelming hype and there are multiple small niggles that add up to a big disappointment and the sound quality doesn't compensate. From a product standpoint it's an expensive luxury item and certain expectations are not met given the price point regardless if it's mass produced or custom made. When users are constantly making excuses for the shortcomings and actively deter others from posting negative first impressions it's a warning sign, most expensive headphones are ruthlessly criticised, for some reason you can't do the same here without being called out.
I hear you about the pad swapping. It adds a bit of anxiety knowing that they can change the listening experience so much that you can feel like you're missing out on your perfect sound. But that's the hifi game for you, I guess. Everything single component can change the sound. For ZMF, pad rolling can alter the sound as much as changing tubes, DACs and amps can. That seems to be by design.
