Leo888
- Nov 4, 2011
Guys, what are the interconnect cables you guys used with the NX1. Curious to know which cable you guys favour over stock.
Thanks Wokei. Any idea if it's a pure silver or silver plated cable. Have got 2 pure copper ic and really would like to try some pure silver and silver plated ones. Have one SPC coming in so might be looking at pure silver.
not too sure man ...seller says its OFC ....
@Wokei
, where did you get that band you use to clip the sansa to the amp? Ones that came with the nx1 are too big.
Buy children size silicone friendship band ..hahaha...or use " O " ring gasket for motorbike ...its small and strectable ...see few post back ...
@michele009
How is the project with the vinyl green carbon sticker....
See the pic...and very small..don't cover the screen
What kind of size is available...links please..basically the me gasket used is about the size of two fingers..
Here's the link
http://www.ebay.it/itm/36-x-1-5mm-O-Ring-For-LED-Flashlight-x-2-Glow-In-The-Dark-Silicone-Rubber-/131152594142?pt=US_Flashlights&hash=item1e894dc4de&_uhb=1
this is 36mm diameter. There are smaller (min 14mm) or bigger ( max 42mm). Two fingers should be 30mm or so.
