Driver loaded, just clicks on changing bit rate and not too bad at all.
You can also try adjusting the gain by using the M button on the remote control. Low gain is 0 db and high is 9 db.Somehow the volume is very low, no matter what I do.
Running on USB mode with Windows 10 and headphone mode.
Been pretty happy with the device. No loud pop as with the Schitt stack, and the screen has been more useful than I thought. Odd you have volume issues - are you using Windows and device volume in tandem?
To use the remote you need to buy a CR2032 battery, which should be included but is not.
Yes windows volume is already on 100%.
I have tried gain mode already. It does increase the volume of course but not by much. Windows volume is on 100%
Hey Bro, you have not said what your problem is, how you are using it and what you are pairing it with?
You have not bothered to fill in your profile for us to see what gear you have and what your budget is, so are we expected to read all the cryptic clues that you may bother to share with us?
Are you saying that it is not powerful enough to blow your ears to smithereens?
Sounds like your unit is faulty!I have tried it with various IEMs, like the Vsonic GR07, Tin Hifi P1 and KZ ZS10. Also tried the line out to my speakers (some random Sony speakers). With all of them, the volume is really low.
Are you saying that it is not powerful enough to blow your ears to smithereens? <-- Sorry, that is just a really silly question. I don't need to have it blowing out my ears to say that the volume is low.
Anyhow, I have already contacted Shenzen Audio (the seller), see what they think.
Any luck so far? Maybe if you mentioned what you are trying to achieve, some of us can help you.Anyone here know how to enter the options menu with the remote? The manual says there are 2 ways: 1st by holding down the knob while plugging the power cable in, 2nd with the remote but it doesn't give specific enough instructions for that. Any ideas?
No luck yet. my issue is with the unit auto connecting to all the bluetooth device that enters pairing mode. Was trying to figure out a way to manual switch off bluetooth so it wouldn't do that but at the same time want to be able to switch it back on without the knob holding / power cable plugging method.
