- Aug 12, 2007
Use lower quality MP3s, WTC. That should tone down the harshness.
Best advice of the day.
... my SR80i were very bright too... especially out of my uDac (since it cleaned up the signal and made it seem brighter). I then picked up a tube amp... and though it's still forward, I was able to tone it down a bit. Plus, I can roll my tubes to change the sound more if I wanted. I hear good things about the Bravo V2 Amp... might be worth a look.
Showoff. I have mostly 192kbps music. That's what I get for being happy with that decent bitrate before. I'd go for 320kbps from now on. I wouldn't wanna waste space on lossless for a negligible sq difference.
Personally I think bitrates are overrated. I can hardly hear a difference between 192 and 320..only if I take time to compare it side by side. oh and 320 and lossless? sound exactly the same to me. That said, 80% of my library is 320kbps, with 10% flac and 10% 192kbps, v2, etc. just because it doesn't cost any extra to rip them from CDs. If this wasn't the case I'd have everything at 192kbps.
IMO Grados are not good for rock. They are way too trebly for a genre of music that is infamous for sibilance. I would recommend Ultrasones and Denon. Bass is very important for rock. Look into the Ultrasone Pro and HFI series. Their highs are not as extreme as Grados and the bass quality and quantity are top notch. They also have more intensity than the Audio Technica M50s which I think is important for rock. However, M50s are more balanced but kills the fun for me.
