Poimandres
- Dec 23, 2009
Ahem turn your head and cough
Yep.. my UD110 arrived today as well. As exiton noted, it sounds excellent. Very transparent. I doubt I could tell it apart from the ODAC in a blind test. I'm using it with my laptop (running Windows 8). The control panel/driver that Stoner Acoustics provided installed flawlessly (I linked to this a few posts back).
The most exciting discovery with the UD110? It works with my iPhone 4 (running iOS7) & CCK ! It did require an (unpowered) hub (between the CCK & DAC), though. I couldn't test Android compatibility since my Galaxy S3 is acting up (it's running the latest version of TouchWiz but I'm fairly certain it's a hardware issue with the phone.. since I've had success with USB OTG/USB Audio with my previous Galaxy S3).
Hi FlySweep!
Out of curiosity, this should work just the same as the CCK right? I have a 5th gen iPod touch so I need a lightning connector.
http://store.apple.com/us/product/MD821ZM/A/lightning-to-usb-camera-adapter?fnode=3a
Thanks mate!
Yep.. that should work just fine, d_marc0. You'll need a (powered or unpowered) hub too, though. When I connected the UD110 directly to the CCK, I received the "UD110 uses too much power" error on my iPhone 4. Any hub should work, btw.
I just got mine today.
It worked on my Galaxy S4.
I used an unpowered hub and USB Audio Recorder app, otherwise it didn't work.
OTG to DAC doesn't work?
This is really frustrating... got my replacement UD110 but still not working on my iMac 2011. Tried bootcamp into windows 7, installed the driver... nothing; reinstalled driver... still nothing.
The device is not being detected by the computer. I tried my wife's Macbook Air, same thing... nothing!
Any of you guys know what else to do? This is supposed to be plug and play right?
Mine works fine in my missus' MacBook - I had to go into Audio settings and select it but it worked with no issues.
Win 7 x64 on the other hand...
You mean Sound under System Preferences right? In my my case nothing shows up under output aside from Internal Speakers. I have a Bass Jump Subwoofer and it even shows up every time I plug it in. But for the UD110, nothing! Really frustrated right now...
Where did you get that usb hub?
