FlySweep
- Mar 8, 2010
That's great news mate! What did you use as a hub to make it work with your iPhone?
Any decent PC hub should work.. I use this one.
Working fine on Windows 7 64bit Home Premium.
When you plug the UD110 into one of the usb ports, if installing device pop up doesn't show up :
>Go into Device Manager, where you'll find UD110 located under Other Devices
>Right click to update driver; let Windows find and install drivers automatically
>After installation, right click on Volume Control icon on the taskbar and select Playback Devices
>You'll see the UD110 listed as playback device. You can set it as a default device, so that whenever you plug it in, it will be the primary sound medium
This worked for me. But, please note that I already had the UD110 driver installed https://www.dropbox.com/s/syvysv17tgu0icq/UD110%20Driver.zip
That's the driver I'm using (dropbox one) it appears to be the culprit locking my PC![]()
was hoping there was another driver floating around >.<
Yep.. my UD110 arrived today as well. As exiton noted, it sounds excellent. Very transparent. I doubt I could tell it apart from the ODAC in a blind test. I'm using it with my laptop (running Windows 8). The control panel/driver that Stoner Acoustics provided installed flawlessly (I linked to this a few posts back).
The most exciting discovery with the UD110? It works with my iPhone 4 (running iOS7) & CCK ! It did require an (unpowered) hub (between the CCK & DAC), though. I couldn't test Android compatibility since my Galaxy S3 is acting up (it's running the latest version of TouchWiz but I'm fairly certain it's a hardware issue with the phone.. since I've had success with USB OTG/USB Audio with my previous Galaxy S3).
AFAIK this driver is particularly for adjusting bitrate settings for the UD110.
Try uninstalling this driver (and restart), and then plug it into your PC and let Windows do its magic.
I think that might work...
