No. I am too cheap to have both at same time
Yea... but you can always unsubscribe and just try to a/b. For me, its not whether am cheap, just cannot afford.No. I am too cheap to have both at same time![]()
Yes. Trying nowHave you personally tried Quboz ?
Well, can give subjective opinion between Quboz and Tidal sound quality with the same format.Yes. Trying now
Just as I thought! Running on app instead of software right ? By software I meant Roon, Jfemto or MusicBee... etc.Canāt hear any difference. Tidal cost less.so I prefer Tidal(qobus offer a little bit higher quality on some album)
Yea but did you use music bee for both Tidal and Quboz when you try to a/b ? And daily usage do you use Musicbee for Tidal ?I use musicbee for my own music(cd rip/buyed digital)
Musicbee is free and great
No I didātYea but did you use music bee for both Tidal and Quboz when you try to a/b ? And daily usage do you use Musicbee for Tidal ?
Talking about offline in windows app.
In qobus , the offline content show info like flac,quality, etc.
No offline in Tidal win app.
One way would be to create playlists of your favorite genres. Then download the playlist to your Andriod device.Does anyone happen to know a simple, streamlined way to āofflineā (download) an entire tidal library to a new android device?
I just got a new Hiby R5 gen 2 player (Android v8) which will be coming with me on a trip soon, so I want to load it up with music as quickly as possible. Iāve logged into tidal, and see my whole library there. But the only way I can see to offline albums (that are already saved to my library) is to manually click ādownloadā on each one. This works, but is very tedious to download everything one by one.
It would be nice if there were a way I could instruct tidal to offline everything in my library at once, and just let the download queue run overnight.
