Feb 6, 2016 at 1:29 AM Post #2,146 of 5,260
Tidal / Exclusive Mode also has trouble picking up my Schiit driver on a consistent basis; it allows me to select it, but I get the error message at the top left that says "Device is in use by a different user, device or service." It prefers my ASIO Bridge.
Feb 6, 2016 at 2:04 AM Post #2,147 of 5,260
You will most likely have to uninstall Asio Bridge to get it to work. Asio Bridge is simply the other Service in use.
Feb 6, 2016 at 3:13 AM Post #2,148 of 5,260
Makes sense, thanks. There now seems to be no benefit from me running ASIO?
Feb 6, 2016 at 4:33 AM Post #2,149 of 5,260
It is very system dependant what sounds best. I recommend to try it. You can always install Asio Bridge again if there is a slight step down in SQ.
Feb 6, 2016 at 10:14 AM Post #2,150 of 5,260
Having issues after the update.
Tidal keeps skipping tracks when using my Chord Mojo and in Exclusive mode. Turning off exclusive mode seems to fix it.
Anyone else getting same issues?
Feb 6, 2016 at 11:06 AM Post #2,153 of 5,260
Feb 6, 2016 at 11:55 AM Post #2,155 of 5,260
Well ASIO bridge got me nowhere haha. The documentation is terrible and the GUI seems like something someone made as a freshman project. Tidal is set to pipe into Bridge and I can see it doing stuff when I hit play but... okay? Great. Now what? There's nothing on the application to select the Dragonfly as my output. Clicking "Select ASIO device" doesn't give me anything except "remove", and the ASIO panel button is literally non-functioning.
ah well. Was a fun experiment.
Feb 6, 2016 at 11:58 AM Post #2,156 of 5,260
Click at the top of the black section right below the Select ASIO device.  Sorry I'm not at my computer with it installed but I believe if you click on the first line of text in the black area it will give you the option to select output device.
Feb 6, 2016 at 12:17 PM Post #2,157 of 5,260
This is all I get. :\
Feb 6, 2016 at 12:27 PM Post #2,158 of 5,260
To use asio bridge with tidal, this is the only thing that works for me, as i found other advice here never worked.
Install asio bridge and leave it alone.
Next, in the windows speaker icon in the bottom right hand corner, right click, select recording devices, click on hifi cable and configure. A new box opens...select "listen to this device" and from the dropdown menu in that same box, select the audio device you want the music to play through.
Then, go to tidal, settings, streaming, and select hifi cable.
Sometimes, you may have to uncheck "listen to device" when your done with tidal and want other audio to play, like youtube.
I forgot to mention that you need to have the hifi cable playback and recording set to 16bit 44.1khz for tidal, in windows.
Feb 6, 2016 at 12:35 PM Post #2,159 of 5,260
giving this a shot. Thank you!
