moiist
- Jul 8, 2013
Thanks for the reply
Im trying to get my head around all these connections and chords. I currently dont have a sound card, so if i was to get the amp it would connect from the White and Red audio plugs to the motherboard through either optical or USB?
If i was to pick up the DAC too, it would connect to the amp using red&white cables? I think i might pick up a DAC too, as i will probably buy a soundcard in the near future. I have a feeling once i start going down this audio road i wont stop, but damn, it can be so expensive!
edit: one last question (for now), how do speakers come into all this? I currently have some below average computer speakers, which i hope to replace sometime with some better non-USB powered speakers. Im just trying to futureproof as much as i can.
Congrats on the headphones, the MDR7506s are a great starting point! The Magni is a perfectly good place to start for an amp, and you may find it's all you want or need.
A DAC converts your digital audio into an analog signal (which is what you ultimately need since headphones don't understand ones and zeroes). Your computer has one built in for its headphone and speaker output. A separate DAC will typically connect to your computer through either USB or optical (if your motherboard or sound card has the option) and does the conversion for you. With an external DAC your connections go: PC > DAC > Amp > Headphones
If you get a USB DAC (like the Modi for example) then it'll show up the same as an external sound card in Windows.
