I'm now testing them with the 20 ohm Hiby adapter ... more fullness in the mids, but how much more volume it takes ....
Metallica's drums get inside you.
I’ve tried pure copper (LSC08), and a pure Silver OCC Litz cable. It sounds amazing with the silver. So much more precise and detailed (which I didn’t think it could get more detailed....)
The copper does add weight to the whole spectrum but is definitely darker in sound. Not as pristine as the silver cable IMO.
Is it not too much bass? I was leaning toward either the clairvoyance or the Monarch with the 20ohm adapter (to add more mid bass). Has anyone heard these two?
To me, Monarch with 20ohm adapter is not too much bass. Yes it’s considerably more bass than stock, but the way the Monarchs is tuned, it never bleeds into the mids.
I am listening to the Monarchs after a small burnin with the cable I had saved for them... the Fiio LS 2.5D and I must say it has greatly improved the listening experience. The lows are even more controlled and less overflowing while the highs have become even cleaner and more enjoyable. The original cable although of good quality, when I wore it seemed to have a rope around my neck. For how much they cost these Fiio work wonders and I would not be surprised if they were also superior to the 170 euro trimetal Fiio RE cable which however have the replaceable jack which however is not needed if like me, for the same price, you buy two high purity silver litz like I did . The only negative note is when connecting them because they are very thin and therefore delicate, but the 224 silver threads (100 for the original) they are made of sound wonderfully. Now the others I have left are just waiting for the arrival of the IER-Z1R for a match on par with the Monarch.
If you can get a good fit with the Z1R you are in for a real treat, and I’d be shocked if the Monarch can match their musicality, phenomenal, speaker like soundstage and movie theatre like rumble! The Z1R are top dogs...
I really like the Pioneer SE Master 1, and been told te IER-Z!R is the only IEM that has similar sound signature , huge soundstage, deep bass perfect for movies, just like floor loudspeakers. Now if Monarch will match that at a lower price, will be amazing.
