I'm really impressed with the phantoms. I checked out that material that is glued to the backs of the grills and it's almost an unbreathable plastic. So I've taken out the foam and removed that material from the grills. I swapped the pads to the perforated brainwavz xl. I couldn't be happier for the money. They may not be the best design out of the box and some of that you can't change easily but what you can simply change in minutes turns them into very impressive headphones.
I can't use them with my cth amp because at higher volumes the amp cuts out and goes into protection mode. I'm guessing from the low impedance....not sure.
Mods I recommend is Change the earpads while the earpads are off remove the rectangle piece of foam and put it aside. I'd go with ZMF suede Universe pads or Brainwaz xl.
Next take off the grills and peel the fabric off. This fabric doesn't allow them to breath. Before putting on the grills look at the two circle foam location. You will test with one circle foam or take the rectangle foam and place over the driver. You will need to hear which foam is better, I like the rectangle but it's subjective.
That's it.
I guess going balanced will improve separation/sound-stage and low-end tightness/texture and general PRaT.
Still waiting on my balanced source to release to market next 7 days.
EDIT: I wonder which more expensive $700+ planar Phantom is closest to in SQ....
I'd wait for the M1070 and see if they fixed the M1060 if your on the fence. I'll be looking at it.
In my collection I have my end game headphones so I want to collect lesser priced headphones from china or made in china. Chifi bug bit me. So far got four chifi unit see them in my signature.
The balanced improves things across the board. I don't know what headphones it's like as far as SQ...
For the balanced cable I'm using the one that came with my Sendy Avia's.
Folks - given the strength of the Phantom’s magnets, I personally would be uncomfortable not having something to screen off the spaces between the grills. Who knows what small metal object on my desk will be pulled in and do some damage... any suggestions for a more breathable black fabric that can still provide a barrier?
Folks - given the strength of the Phantom’s magnets, I personally would not be comfortable not having something to screen off the spaces between the grills. Who knows what small metal object on my desk will be pulled in and do some damage... any suggestions for a more breathable black fabric that can still provide a barrier?
You can always use an old modder's trick and get yourself some black run resistant lady's pantyhose. It's thin enough to be acoustically transparent but still provide you the protection you want from dust and debris.
