Symbio F is foam and Symbio W is hybrid silicone + foam. But I've never tried those tips.
ThieAudio Monarch MKII Experience
- Thread starter MusicSat
Usually Symbio W do the replay a bit V-shaped. I didn't like them on MMk2.
Best foam tips for MMk2 so far for me are Comply foams with the wide opening and w/o any protective mesh in it.
Stock tips are also pretty good just you need the right fit.
thanks for your reply.Usually Symbio W do the replay a bit V-shaped. I didn't like them on MMk2.
Can someone who owns a pair please help me out?
I took a look at mine the other day and saw that all the outer holes of the filter are closed, on both sides.
Now I am wondering if this is normal or if this is dirt from my ears. Could someone please check on their unit?
I always try to keep my ears clean, so that would be a bummer.
I don't really want to spend 200€ on some IEM vacuum cleaner to clean it.. Or is there a cheap alternative?
![monarch.jpg monarch.jpg](https://cdn.head-fi.org/a/12097599.jpg)
psp123
- Jan 5, 2015
I bought mine a couple of weeks ago and they look the same. I think it's normal.Can someone who owns a pair please help me out?
I don't really want to spend 200€ on some IEM vacuum cleaner to clean it.. Or is there a cheap alternative?![]()
Plastic syringe with wide nozzle. But you need more hands or better plastic tube that you put around the iem nozzle and the syringe nozzle than pull back syringe piston. And dissemble clean, put together and pull back the piston ....Can someone who owns a pair please help me out?
Looks normal to me, but If your filters ever do get gunked up, you can always contact Thie directly and they will provide extra filters as well as a very nice pair of tweezers for around $10USD. Changing the filters is very easy. I did it to my pairCan someone who owns a pair please help me out?
Alright thank you! Then I'll leave it at that for now.
How did you change the filters? Can you just like unscrew them? I don't want to try and maybe break something now.
It's understandable to be so nervous, I was too. I have experience changing the nozzle filters on cheaper IEMs which gave me some understanding and also practice doing it. If you have some cheaper sets laying around, to get over that concern you naturally have, give it a go on those. It's as easy as using a very sharp pair of tweezers to pry the filter off the nozzle opening and then place the new one in the same spot. I was surprised that it was the same process as a pair of $50 Tripowin Mele, but hey, that's chi-fi for ya.Alright thank you! Then I'll leave it at that for now.
RIGATIO
It doesnt look like a dirt to me, rather like some sort of an adherence to keep them in a nozzle. No need to clean them imo.Can someone who owns a pair please help me out?
Thats normal. Mine had outer holes closed right out of the box.Can someone who owns a pair please help me out?
how sounds tone and SQ different meze rai penta vs MMii ?
any list recommended replacement cables guyss? that probably increase the amount of sub bass or detail
Andrew_WOT
- Jan 18, 2004
Switching from OEM can only improve ergonomic and esthetics, which is not a bad thing as original is quite thick and heavy.any list recommended replacement cables guyss? that probably increase the amount of sub bass or detail
Dunu has reasonably priced modular offerings.
Heroquetarro10
I would try out new ear tips or a different eq before the cable, it would be cheaper for you and will probably give you the sound you want. I’d try the Azla sednaearfit regular or short editions, they work well with the monarchsany list recommended replacement cables guyss? that probably increase the amount of sub bass or detail
Total: 4 (members: 1, guests: 3)
