Hi all L3's Owner,
My #038 ClockWork L3s is sounding soooo G O O D...
But with the flaw of the straight nozzle tips design, and with eartips sensitive SQ, i've came to a conclusion and solutions...
I've tip rolled Spinfit CP100 (for my PP8s), CP240, CP360, Acoustune AET07 and AET08, JVC Spiral Dots, Dots Plus and Ortofon.
And upon closer inspections, i've found out due to its tips sensitivity, L3s like the straight bore type tips and sounds best with the Ortofon.
My interesting finding is, with the narrow type of bore, the sound will be more high rolled-off while the low a bit muddy, hazing the detail of the low section
While, the wider the bore is, like on the Spiral Dots, affecting the depth thus also the seperations. The vocals are also congested and felt flat
So, the best tips IMHO is the Ortofons. When looking directly to the nozzle with sound tube facing us, they don't block the nozzles at all. Just straight...
And lastly, with the design of Ortofon Eartip's straight bores without notches, they tend to stuck in ears when the IEM's pulled. So the simple solution is, i apply a 1.5mm of cable shrink wrap on the tips of nozzles to hold the Tips and it works!
Now, i think that the L3s is my ENDGAME now. With the 01 switch, i got all the frequencies right, at least in my own standard...
Bonus: with the same Mighty Shrink Wraps, i solved the QDC-styled lose pins too. Just have to choose the same diameter tube, that is isn't too thick...
