Ciuvn
- Apr 26, 2013
instead of move up to metal ver...I decided to jump up to Opus #2 :v
Nice! Wish I had the metal version, but I settled for the plastic one instead. I'm really digging this DAP. Not sure I would to be honest, so it's been a pleasant surprise.
I had my doubts but the screen is not bad and my compare is a Note 4 with 2560x1440 quad blah blah with gorilla glass 4. I expected to compromise my visual ADHD/OCD but it looks fine. Not good for pics and vids taken of it, but in hand it is pretty dope. The sound is excellent. I wanna know what the improved OP amp used is but the sound is awesome.
I passed on the #2 because I have multiple ES9018 chip based gear. Both regular and portable versions. You folks enjoy the #2
I am very pleased with this beautiful device. I expected to be bummed so maybe that's why i am so stoked.
So you expected to be unimpressed, too? I didn't read anything about it that really grabbed me, so I held off buying one for a long time. I'm glad I finally pulled the trigger!
http://www.e-earphone.jp/shopdetail/000000102996/ct2827/page1/recommend/
will this adapter work with regular 3.5 to 2.5 trrs?
Looks like the right one
To convert 3.5mm TRS to 2.5mm TRRS balanced? That not going to work because TRS has a common ground thus your L-/R- will be tied together, and can't be split into balanced where you have L+/L- and R+/R-. It works the other way, going from 2.5mm TRRS to 3.5mm TRS where L-/R- are tied together. Unless I misunderstood you which way you are converting? Maybe you meant 3.5mm TRRS balanced to 2.5mm TRRS balanced?
Btw, for any adapters/converters, I would highly recommend Lee's (@zhibli06) $5 adapters: https://www.veclan.com/engappliance_sel_one?eng_ApplianceVo.eac_id=4 - when you scroll down VE Monks page, there is an option to select just an adapter (from 2.5mm TRRS to 3.5mm TRS, 3.5mm TRRS to 2.5mm TRRS and vise verse). Actually, very durable connectors, regardless of dirt cheap price.
Those are mine ^^
And the link from e-earphone is 2.5 balanced to 3.5 balanced @twister6 ^^
Sent from my SM-N910S using Tapatalk
Those are mine ^^
Thanks for the translation
How about taking my dual 3.5 for the PHA and converting them back to a single connect? That would be a 2 into 1 rig. Maybe that is more authentic and truly balanced. Any help is appreciated. I like balanced a lot. Certain recordings stand out IMO so i wanna keep my ex1000 in balanced using this cable
