pr0b3r
- Mar 18, 2016
Still enjoying my trusty ol' Opus#1
Ibasso IT01?Still enjoying my trusty ol' Opus#1
Ibasso IT01?
I Demoed it for a while and it has a tuning which is very similar to the JVC FXH-30 which I like a lot. The IT01 was better in treble extension while the FXH-30 had faster and deeper bass.Yup. With the original cable reterminated to balanced 2.5mm.
The main difference is the price though. The FXH-30 is only about 35 bucks in Japan.
Haha yeah, I got another pair as a spare when I went again last year. It's the best budget iem I've ever tried. It scales EXTREMELY well too. There's always a noticeable improvement when I upgrade to a better dap. BTW, it sounds better the longer you use it. I compared the new one and the 2 year old one and it's a day and night difference. No joke. If anybody doubts burn-in, I'll just let them try the old pair and the new pair.Sounds like a good deal to me. I should check that out when I get the chance to visit Japan again. When I last visited, I was still not into hi-res audio stuff. What a waste! Haha!
The IT01 is already a good buy for me. I didn't regret it one bit the moment I opened its package. Wish I could try the IT04 next on my Opus#1.
That depends on what type of sound you want. Personally I don't like any of the higher end jvc models because they don't sound clear enough for me. I like very transparent sounding IEM's which allow me to pick out every instrument in a song. Im more of an energetic and detailed sound guy rather than a laid back and smooth sound guy. If there is a detail or nuance to be heard in the song, i want to hear itNow you got me curious! If that's really good then no need to get the higher priced JVC models. My contentment is pretty shallow for sound a I'm not much of a critical listener but I still look for some good aspects of a gear that will fit my preference. I'll put that JVC iem on my must try list. Thanks!
It definitely is. So far only the Hifiman Sundara trumps it in that aspect. It also brings its level of realism to the next level.I see why you have the Opus#1. I kind of like both or something in between but not totally flat or neutral. I also pick out which gear to use depending on the music I listen to. But it's good to have a nice all rounder IEM/earbuds on the go. Is the JVC a good all rounder?
Currently I'm using the Echobox Finder X1 and while they are much more technically capable than the FXH-30, they do sound brighter in the treble and sound less realistic.Check out the JVC FD7 too, I think it's a slight upgrade (little more balanced, less crispy/grainy sounding in treble) and a better all-rounder, although not nearly as good a value as FXH30, which I rate up there with the original Carbo Tenore (they make a good set too since the sound signatures are contrasting)
weird request but anyone with the opus1 metal can you weigh it?
I get:
211g w/o case & 232g with gray leather case (Both w/2 micro sd cards inserted)
