majo123
- Jan 1, 2016
Comparing the standard opus and the metal edition, the standard opus has a thinner sound. The standard Opus sounds like it is more transparent and clear but the metal Opus has superior instrument separation though if doesn't sound as clear. Probably due to the soundstage depth. The standard opus sounds clearer and more articulate due to the thinner sound but it's also not as dynamic. Soundstage wise I found the standard opus to be a bit wider than the metal opus but it lacks depth and sounds 2d compared to the metal opus.
Depending on the price it MIGHT be worth it. But generally you're better off moving to a higher tier of DAPs like the X7ii. Getting the the N5ii would generally be a smallish upgrade in sound but will definitely be better than the Metal Opus if you prize clarity and neutral sound over warmth. I have not heard the Opus 1S so I can't comment on that yet.
Thanks again for your thoughts im still debating which rd to take as you can see.
Thought I might pick up a metal. Not certain on the 1s though from what I have read and also spoke to a couple of guys that own both, 1 said he actually still preferred the 1 and the other said not much of an upgrade.
