I could not fit them in the same position, they are bigger than the stock caps.
Are your Nichicon fine gold caps bigger than the caps that were installed?
I had to install mine this way:
Then I had a bit extra space and I saw that some ceramic SMD caps (bottom board), touch and could short circuit the metal caps top, so I used some kapton (yellow) tape to insulate that:
I also changed the 2x OP275 and LM4562NA with the the same brand and models but imported from USA.
The sound changed a lot, it has a lot more detail, it is much more brighter and has less body.
I find it a bit too much bright now and it needs a bit more body, so I need to change this again. This is the op275 sound signature I know from several other HW.
I'm not going to reuse the Chinese opamps and caps that came with the player, I don't recognize the sound of this Chinese opamps with the models printed on top of them.
On another note, I measured the player takes 1A of current to charge an empty battery faster:
