Ivan TT
No worries, neither am I.I was consider in the z3 as well, but I had no idea that it would need a different opamp since they all seem to have opa275, I thought I would get them all replaced, so the dsd and z3 have different voltage? Do you know where I can find all that info? I keep looking around but find it hard to figure some of these things out, it doesn't help that there are Soo many variants and I am not a electrician, haha just a sculpture
The easiest way is to dig threads on player.ru forum, but they are massive in size by now.
DSD has 9V rails, Z3 - 13V or thereabouts, so only DSD is safe for AD8066. It’s quite easy to reduce Z3’s voltage, but involves desoldering and soldering 0603 SMD resistor.
By the way, as good as AD8066 is, there’s one caveat, quoting datasheet: “6.4 mA/amplifier typical supply current”
Seems low, but cheeky AD cheat: it’s per amplifier, so dual AD8066 has 12.8mA quiescent current, resulting in about 1/3 reduction in battery life and 1/3 increase in running temperature.
