Themilkman46290
Hey guys, are these new updates for the older dsd or just for the newer dsds. Wanna try but I have the 95, 90 and single 97 versions
I tried 0.4L+M and 0.5b on my single 4497 that was linked here but all of them are not working. After reboot only a gray screen.
On Ghosts Taobao link the latest version for the single 4497 is 0.4K, I flashed the 0.4K again and it's working. I don't know how old my DSD is as I bought it second hand, maybe there are older versions that don't support the newer FW.
So before try to flash make sure you have downloaded the 0.4K:
http://pan.baidu.com/s/1skLjk4l
I also found out that the flash process is a little different for the 0.4K, after flashing to 100% some erasing message appears before turn off, the other versions just flash and then turn off.
I checked the Taobao store again, the DSDs got the 0.5b version, unfortunately the file is called ZiShan_DSD_0.5b.rar without the s, this is not working for the DSD. So far it seems the DSD newest FW-Version is still 0.4k.
Could anyone try to flash his single 4497 to a newer firmware than 0.4k? I am really curious about the FW that was postet here before if it is working for someone or not.
Where did you download it? Thanks!0.4L is working for me
I'll upload it on mega when I'll be back from workWhere did you download it? Thanks!
Thanks so much, unfortunately it's not working in my DSD, guess its a hardware version issue then, anyway I am fine with the 0.4k so far.0.4m was reposted a few posts ago and works fine for me on single ak4497 : https://drive.google.com/file/d/1TB4ISAyX6dcrPClVR6Pr3UjcVJD3zB_c/view
I had really bad screen flickering with one of the previous ones tho, while others didn't seem to have the problem. I suspect there might be different cheapo screens used on those devices, and embedded systems like that need the proper screen driver to work, might be your issue Area511
Thank you too very much - also not working for me. Seems I have bad luck with Zishan's stuff after the U1, I just keep my 0.4k version and never touch it again, also no Zishan Stuff again, really disappointed.Here you go: 0.4L
Sorry for being late
Received dual ak4497 dsds today, more of the same, various crashes when switching audio files, long boot up "caching"... God knows what, and not actually caching it because it does the same every boot.
But usb-c so that's cool.
Speaking of the hardware in the Single AK4497 DSD, and Dual AK4497 DSDs - which component on the Digital circuit board do we believe is limiting the USB DAC function, so that it maxes-out at 16-Bit / 48-KHz?
I know that my Dual AK4497 Topping D70 DAC ($475) is capable of 32-Bit / 768-KHz, and even small USB DAC Dongles ($7) from AliExpress are capable of 32-Bit / 384-KHZ.
