Themilkman46290
Thank youOK. Thanks for the thread link. I have put it there then.
They won't let me joinMaybe some of You know this lovely place for all Zishan fans. I found this today
https://www.facebook.com/groups/624906874983953/?ref=share
I waited about 1hr to join. The old group with "... Enthusiast" on the end of name is probably no longer active.They won't let me join
Nope, they blocked me, happened a few months back, I joined, I was enjoying it, then waze disappeared, I can't look them up, kind of weird, don't know why they banned me but o well, screw them..I waited about 1hr to join. The old group with "... Enthusiast" on the end of name is probably no longer active.
This working perfectly!
I see 2 groups in similar names and sent request yesterday to join:Nope, they blocked me, happened a few months back, I joined, I was enjoying it, then waze disappeared, I can't look them up, kind of weird, don't know why they banned me but o well, screw them..
There's the regular and the PRO version of ak4499, the difference being better opamps in the the PRO from what I've read.
ak4499 has 2 dacs inside, the result is better specs on paper than a dual ak4497.
ak4497 dual is more expensive than the the previous ak4497 single.
I can't recommend or comment because I don't have the new models.
You'll have to read the last pages of this thread, some users bought them.
Dual DAC also is must have for people who really want pure balanced systems DAC -> AMP -> headphones. As you see also balanced output have ~50-100% more power in mW and Vrms in same aplication if manufacturer decided to design audio rail symmetrically.Honestly, when doubling dacs you are just lowering the THDs to levels nobody human can discern compared to the single dac if it was already good (which the AK are). And the headphones have higher THDs anyway... So it's purely a marketing/crude paper numbers stunt.
I only got the dual ak4497 because of usb-c, but would've preferred a single version for better battery life.
However, you should know that DSD4499 has an inverted polarity
on the headphone output, that is, the phase is inverted 180 degrees and this is
wrong.
Hi,
The polarity is inverted in what outputs:
3,5mm PO, 3,5mm LO, 2.5mm balanced, all?
Is it a circuit design problem or firmware?
What effect does is have in sound ?
Can this be "fixed" by making a special pair of headphones/earbuds with both drivers soldered with reversed polarity ?
Thanks
What you offer is a "pseudo" solution.Thanks for extensive explaining the problem and your fix.
Yes, if we reversed polarity in some headphones/earbuds then they could only be used in this player.
It was more to test the correct polarity than to make a permanent solution.
In some earbuds with detachable cable, the reverse driver polarity could be made in the cable.
Just an idea for someone that can't make the fix inside the player.
BTW, I never tested/listen how reversed polarity sounds.
Some people even like this sound, it is not bright, highBTW, I never tested/listen how reversed polarity sounds.
