calico88
- Oct 7, 2008
I got a friend in the u.k. that is willing to bring me some stuff, I was thinking of trying digikey.I do know that Arrow Electronic Components has offices in the UK - https://www.arrow.com/en/support/co...sion=electronic+components&country=GB_Offices
Awesome case, looks great, what are the dimensions? How does it do with heat?![]()
got email from arrow support, they said the reason I had split delivery/order is because they have different warehouse.
that's why I receive 2 boxes for 1 time order and arrive at the same day, but fedex charged me about US$4 for handling fee for each delivery.
Woody casing finally ...
Can anyone tell me how quickly they deliver to Europe?
62x35x87 (mm).Awesome case, looks great, what are the dimensions? How does it do with heat?
Great work!!62x35x87 (mm).
Have not tested running till battery drop from fully charge yet, so far it’s just warm (2hours).
Thank you,i went for the volume knob ak4495, it says also hard solution D3002, not sure what that isStock, if you have anything with b.a. or most your stuff is sensitive low impedance then the ak4495 is better, if you use full size or high impedance stuff or want balanced then or plan on modifications then ak4497 is better
Could be the buttons, or the battery, for example dsd had an extra button inside itI bought a Zishan Z3 from an online shop and when it came it has something rattling inside. Anyone knows what it is? I don't want to void my warranty for something not that crucial.
Also thought about that it may just be the battery cause it's kind of on the heavy side. Thanks for the reply.Could be the buttons, or the battery, for example dsd had an extra button inside it
