Themilkman46290
Are you talking about xuelin h8 tuner? Looks prety interesting but if i had $700-800 for a dap, i dont think i would be modding anything, just buy the right dap from the start. Thats why this dsd is my baby, good, cheap and upgradable, and not flashyYup, TPS7Aхх family, both positive and negative one.
These are quite low-noise (compared to DC-DC boost converter), also the way negative rail is arranged in DSD creates uneven voltage on positive and negative rails, and negative rail is only capable of delivering a fraction of current (I believe). So all in all these SHOULD make an improvement, but soldering them in place of the inductors is tricky, so much kudos to So-Hm for getting these LDO going, I would not even dream of attempting it. On the other hand capacitors (both electrolytic and ceramic) should hold enough charge/provide sufficient filtering to clean up +/- rails, so this mod may or may not provide significant gain in terms of quality.
I also note that more recent and advanced chi-fi DAP designs (IHIFI Tuner) use TPS7Aхх family LDO in a similar way, but utilise more recent/better specification QFN form factor ones.
Or you can get one of those:
https://www.ebay.com/itm/TPS7A4700-Low-Noise-Power-Module-RF-Audio-Board-3V-3-3V-5V-12V-15V-1A-Adjustable/153160529239?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
So far i feel it sounds better then the fiio x5 (almost bought it used last year) and definitely sounds way better and works alot better then the fiio x1ii (complete junk, sounded digital, froze and crashed if i even thought of it) but they are "sexier" looking for sure, but the x1ii cost me $130 with tax the dsd cost about the same but it cost me about $60 to upgrade so that comes out around $200. The fiio x5ii is about $350, and the x5iii is about $500,so i am still blown away by this player
Cant wait to see if zishan will update to ak4499 chip, hopefully they make it more like the ak4495 version, still the most versatile and best sounding stock, but with the edition of a 2.5 balanced instead of the line out
