AudioDuck
Thank you! True, that would be an option.Darn. In that case the only other thing I can think of is adding a something like a schiit sys between the wa2 and your amp. Adding another component in the chain isn't ideal, but that depends on how annoying reconnecting your rca wires is
I think the current plan will be to use @vlach ’s suggestion about shutdown/power-up sequence.
Longer term I’ll “bite the bullet” and get a passive preamp (Luminous Audio makes a small/purist one that isn’t expensive per se) that is adjusted for my system. Luminous does that as part of the purchase, so the gain limits of a passive unit aren’t an issue.
While that negates the benefit of having the WA2 as part of my speaker system, I ended up finding such a good power amp that I trust it will sound great with a passive preamp… and the goodness of the tubes will be “reserved” for headphone listening.
