Sep 13, 2024 at 11:24 AM Post #95,251 of 107,364
1
Precisely!
Sovereign Symphony 8 Wire is the most astounding IEM cable I've tried & nothing else has come close - but retails for over USD $10,000. If it were cheaper I'd own one.
It was the cable that inspired me to ask Penon if a 12W version of their 8W ASOS+ was possible, leading them to create the 12W ASOS+X, which doesn't perform to the same level as Sovereign Symphony 8W but is more ergonomic and only $319.
The staging, dynamics, resolution & bass such monstrous cables can potentially achieve is truly next-level. 8 wire cables have been all the rage for years, but I'd love to see 12 wire behemoths become the next BIG thing. Most of us own multiple IEM cables anyway, so it's perfectly possible to use petit 4W cables when we're wandering around but break out the 12W anaconda for stationary listening at home when sound quality becomes paramount
10K for a cable lol. Better be made with diamonds! Bummer if stock sounds better
Sep 13, 2024 at 12:32 PM Post #95,252 of 107,364
To usher in the weekend, I invite you all to check out my new review of Beat Audio's Billow MKII and Oslo MKIV cables!
It's been a crazy week for me, two big reviews - but it's been worth it. The BA stuff is amazing, and if you've never heard it, find a way.
Sit back, grab your favorite libation, click the gold letters and read on :)
BEAT AUDIO: LADIES IN GOLD
You can also read it on my website here
Sep 13, 2024 at 12:58 PM Post #95,254 of 107,364
1
If the stock sounds better, then the journal will start to look for a perfect IEM to match your 10k cable, could also be fun.
Sep 13, 2024 at 1:51 PM Post #95,255 of 107,364
Would love some blindtesting. 10k.... that's a crazy amount... That's 2-3 TOTL IEMs...
Yeah I’d rather get the 2-3 totl iem’s. At least you get something for your money compared to a wire
Sep 13, 2024 at 3:14 PM Post #95,258 of 107,364
How comes a copper or silver or xxplated/shielded cable comes costing 10000$ ..or , what are the hidden costs , if and when they are there , to justify the price ?
The market. And marketing. They really don't need to justify anything. If people keep buying they'll keep making, and push the ceiling higher and higher. I have no doubt the elegance, extravagance, and in some cases technical advancements (whether they make any difference or not may be debatable, case by case) will make some happy.
But buying a super expensive cable never guarantees it to sound better than a super cheap cable. The God of gear synergy doesn't work in that manner.
I've owned many expensive cables that have sat around collecting dust cause cheap or even stock were better and more expressive pairings. I don't get offended companies try to sell things and push the ceiling at all. Have at it.
Sep 13, 2024 at 4:22 PM Post #95,259 of 107,364
Awesome! Wait until you hear the 70 or 80 then... 70 has more bass slam, 80 are reference perfected.
otherwise, performance long is really good. the short didn't seal well for me, it didn't have any support and there was less sub bass, the middle was a bit loud. then long fixed everything... Although at first glance it seemed scary big, but then I don't even understand, it just disappears in the ear...
Sep 13, 2024 at 5:32 PM Post #95,260 of 107,364
Music shopping tonight... huge fan of Trentemoller and been very excited to hear this latest release, does not disappoint - his clear influences from the likes of The Cure evident yet again.
A new Floating Points was a surprise, and loving what I'm hearing... proper dance floor material.
Sep 13, 2024 at 6:12 PM Post #95,261 of 107,364
Exactly my experience! :D Have fun :)
Sep 13, 2024 at 8:06 PM Post #95,262 of 107,364
New article on weibo about the EA4: http://weibo.com/5819639917/5078082...trans=5819639917_5078082007075645&s_channel=4
EA4 "Evolution of Design" — 4 Practical Improvements for the User
As a flagship tube amp, the EA4 sticks to our philosophy of “good things take time”. After several adjustments and improvements over different versions, the final EA4 now combines top-grade sound quality with the best user experience. We'll break this down into two parts: exterior design and internal design. This first part is giving you an in-depth look at this new product.
(Note: In the images referenced in the article, the higher the position of the EA4 version, the newer it is, meaning the EA4 in the top image is the final release version.)
Improvement#1:Larger Heatsinks for Better Cooling
The case design is where you’ll notice the most obvious changes. Compared to the early flat-surfaced prototypes, the final version introduces several grooves. We know that the final version of the EA4 can output a maximum power of 6500mW@32Ω, which generates a lot of internal heat. If this heat is not transferred from the inside to the case, it will cause the internal temperature to rise and affect the lifespan of the components.
For a high-powered tube amp like this, the large surface area equals better heat dissipation. That's why we added cooling fins to the case —it’s the most effective way to increase the area that transfers heat.
Improvement 2: Clear Volume Display to Prevent Sudden Loud Volume
Volume scale design :During exhibition and our internal tests, we noticed many users preferred pairing the EA4 with IEMs, most of which are low-impedance. With the EA4’s high power output, there’s a real risk of "ear-blast" volume without some kind of volume display. If you had to adjust the volume to the lowest setting every time before using it, and then slowly raise it after putting on the IEMs, it would be too troublesome. Therefore, we considered adding a visible volume scale.
Custom Potentiometer: Standard analog potentiometer don’t show volume levels, so we had to specially design a potentiometer with visible markings. We had to get it right — the scale range had to be evenly distributed, the size of the potentiometer had to fit inside the case, and the performance deviation between each potentiometer had to be minimized. We also needed to consider the impact of the potentiometer on sound quality. After a lot of tweaking, the potentiometer delivers great sound, a smooth and accurate markings, and minimal channel imbalance at low volumes.
Power/Preamp-amp status indicator light:Additionally, this potentiometer also includes a power status indicator. Since the power button was moved to the rear panel, checking the status would otherwise be a pain. Plus, the LED changes color to show whether you’re in preamp mode or amp mode, making it super easy to know what’s going on.
Improvement #3: Optimized Front Panel Layout for More Tuning Options
Replaced Toggle Switches for Push Buttons to Prevent Accidental Power On: In the early prototypes (see the bottom pics), notice the four toggle switches on the lower part of the front panel. The leftmost switch changed from an on/off power switch to an ILH/ILA switch (Input Level Hold/Attenuation). the power switch,which was too easy to hit by accident, especially when placing in a bag. If triggered, it could leave the EA4 running, draining the battery. To fix that, we moved the power button to the back and switched it to a push button that requires a long press to turn on. We also added a MCU to enable this long-press feature, along with a double-tap option for switching between pure preamp and amp modes.
New ILH/ILA Mode Toggle:The four toggle switches on the front are all for sound tuning, and with the new ILH/ILA switch, doubles the number of tuning combinations. The toggle originally named 0dB/-6dB, but we changed it to ILH/ILA since the -6dB option was too much of a attenuation, making it hard for the preamp to compensate. This also avoids confusion about whether it controls the gain for the amp section.The actual attenuation value for the ILA mode is less than -6dB.
Lowering the amp’s supply voltage for higher current output: Another change is in the second toggle from the left, where the ±12.8/±16V switch was changed to ±13/±15V. Lowering 16V to 15V balances the current output. As everyone knows, when the power remains the same, increasing the voltage will reduce the current, which affects the amp's ability to drive low-impedance headphones. Considering this, we decided to limit the voltage swing to ±15V.
Improvement #4: Power Indicators for a More User-Friendly Experience
Power Button Update: In the earlier versions, the rear panel didn’t have a power button at all. Later versions moved the power button and charging port to the rear. Now, it’s a long-press for on/off and a double-tap for switching modes, all designed to prevent accidental power on.
Adjustment of the charging port location: We also moved the charging port to a better spot, ensuring the charge indicator is always easy to see when a USB cable is plugged in.
the images of each version are actual samples. Every adjustment was made based on our tests and feedback from users. features like the new ILH/ILA button and power switch relocation also require changes to the internal circuitry. Therefore, every external modification also implies significant changes to the circuit board.
Through these revisions, we’ve worked to fine-tune the EA4 into something that truly enhances your listening experience. We hope you can feel these improvements when you get your hands on the final version and enjoy the music even more. Thanks for your support!
Sep 13, 2024 at 10:55 PM Post #95,263 of 107,364
Watercooler Summer Survey Results
At long last here are the results of our recent survey.
Full results compiled here.
Desert Island IEMs
In the interests of time I'm only sharing here the IEMs that 3 or more votes.
Oriolus Traillii/Ti x29
Elysian Annihilator x27
PMG APX/SE x27
Fir Rn6 x18
Campfire Audio Trifecta x15
Subtonic STORM x15
Unique Melody Amber Pearl x13
Fir Xe6 x13
Vision Ears VEX x12
Sony IER Z1R x10
Unique Melody Mentor x10
Aroma Audio Fei Wan x9
Aroma Audio Jewel x9
Noble Audio Viking x8
Empire Ears Raven x8
Dita Perpetua x7
Night Jar Singularity x7
64 Audio u/a12t x7
AK/VE Aura x6
Rhapsodio Supreme V3 x5
Campfire Audio Astrolith x4
Canpur CP622b x4
Vision Ears EXT x4
Sennheiser IE900 x4
Empire Ears Legend X x4
Unique Melody Mason x4
Unique Melody Maven II x4
AK/EE Novus x4
Empire Ears Odin x4
Campfire Audio Supermoon x4
Campfire Audio Bonneville x3
FitEar DC TI x3
Vision Ears Erlkonig x3
Unique Melody Indigo x3
Noble Audio Onyx x3
Vision Ears Phonix x3
64 Audio U4s x3
Forms response chart. Question title: Where are you located?. Number of responses: 113 responses.
North America - 50
Western Europe - 30
South-East Asia - 14
East Asia - 6
Australia - 4
South Asia - 2
Eastern Europe - 2
South America - 1
Africa - 1
Forms response chart. Question title: Which of the following is most likely to be a deal breaker with an IEM for you?  (Check all that apply.). Number of responses: 114 responses.
Professional -> Listener
Forms response chart. Question title: Where would you place your perspective/ideals on this scale:. Number of responses: 113 responses.
Purist (accuracy/realism primary) => Subjectivist (express/experience emotion primary)
Forms response chart. Question title: Where would you place your audio personality on this scale:. Number of responses: 114 responses.
Forms response chart. Question title: If you had to pick one with a slight sacrifice to the other:. Number of responses: 114 responses.
Forms response chart. Question title: What is your most common deal breaker for a source?. Number of responses: 114 responses.
Mjolnir, N30 LE, RS8
RS8, n30le
Hiby R4
Astell&Kern SP2000
Shanling M6 Ultra
320MAX Ti, M9 Plus, SP3000 Ti
LP6 Ti7AE, P6ProTi99, Dx320Max
Wm1zm2, rs8, n30le
N30LE, N7
Cayin N30LE, Sony WM1ZM2, Cayin N7
LP6Ti, SP3000, DX300 MAX
Astell & Kern SP3000, Hiby RS8 and Sony WM1A NPaudio mod V5
Sony WM1ZM2.
RS8, R8 II, WM1Z
L&P E7 EE, Cayin N3 Ultra, L&P 6 Pro
LP P6 Pro Ti. Cayin N30 LE Sony DMP-Z1
A&K 3000, Hiby RS8
HiBy RS8, Cayin N30LE
E7, P6Pro, PAW6P
IBasso DX320 MAX Ti
Dx300 max ss
N8BB, Sony WM1ZM2, and desktop - Holo Audio Stack with MK-465
AK SP3000 , HIBY RS8
1. iBasso DX320 (w/ AMP12 EXN-S NP Mod), 2. iBasso DX220 (w/ AMP8)
Lotoo Mjolnir
M15s
L&P P6Pro, Sony WM1Z, Cayin N30
RS8, N8ii, AR-M2
Sony WM1ZM2, Hiby RS8
1zm2, ak se300, n8ii
Kann Ultra, SP3000 SS, Nipo N2
Hiby RS8 II
E7, WM1Z, SP3000T
Hiby R6III
L&P E7, L&P P6Pro, Cayin N30LE
RS8, 1Z/1ZM2
Cayin N30LE, SP3000T, HiBy RS8
N30LE
Hiby r8 ii
1. Sony Wm1a 2. Sony Wm1z 3. Hiby R3 II
Dx320 Max Ti, LP6Ti 7AE, M9+
Wm1z and calyxM
N30LE
no preference for DAP as long as it can use streaming service and has decent battery l;ife
ONIX XM5, DX300, Hiby R6Pro2
SP 3000, AK SE300, DX180
WM1Z, W1AM2
WM1Z
LP E7, iPhone Dong attached to an iPhone, LP7 Ti
Ibasso D320MAX TI
Hiby RS8, Cayin N3 Ultra
HiBy RS6, Sony wm1z
Sp3000
Tsuranagi+N7, RS8, WM1Z
iBasso DX260, LPGT
DX260
Cayin N30LE, Lotoo Paw Gold Touch
Hiby R3 II, Sony Xperia 10 Series
HIBY R8 II, Sony nw-wm1am2, iBasso DX260
Hiby RS8, Mojo2 Poly
Hiby R8ii, Hiby RS8, Lotto Mjolnir
Cayin N30LE, L&P LP6 Ti, Sony DMP-Z1
AK SE300, M9+
LP6 Ti199, P6 Pro HK
Cayin N8II, A&K SR35, Cayin RU7
FiiO M15S
E7; DMP-Z1; M9+
LPGT
RS8, M9+
Hiby R8II, iBasso D16, DX180
AK SP3KT
COWON PL , CAYIN N7
Sony DMPZ-1. LP6Ti. Cayin N30LE
Dx320 max ti, dx180,
p6proTi, SP3000T(Cu), LPGT
RS8
Lotoo LPGT
HiBy RS8 II
LP 6 Ti
Sony wmzm2
N/A
N8ii; 320Max Ti; SE300
SE200
Lotoo paw 6000
Sony WM1ZM2
Shanling M8
Sony NW-M1Z2, CayinN30LE, L&P E7 SELECT
Hiby r8ii
Dx300MaxSS
N30LE AP
RS6, RS8, Mojo 2
E7, Dx300 max Ti, Shanling M9+
D16?
Cayin N8ii, Sony WM1Z, A&K SP3000T Copper
Ibasso DX320 max ti
Hiby R8ii
Cayin N7
1AM2, RS8 SP3000.
Sony WM1Z
Hiby R8, Ibasso dx320 max
iBasso DX300
A&K SP3000, Cayin N8ii,
Sony WM1ZM2, Shanling M9 Plus, Lotoo Mjolnir
Cayin N30 LE, HiBy RS8
Hiby R3, Hiby RS8
N/A
P6Pro
In your own words:
Apx Se
PMG APX SE
Hiby R4
Riviera AIC10-Bal (headphone amplifier)
Singularity paired with Audiohive Ulan 8W cable. Very surprising pairing
APX SE, Raal Immanis, Chord Dave.
LCD SOUNDSYSTEME SHOW AT Rock en seine paris 2024
Xenon 6
The synergy of Aura EVs + Chiron Nova EA combined with LP6TI
A&K SP3000
Procuring the Trifecta!
Solid wood Sharona
L&P E7 EE
Revisiting Fir Xe6 after giving up on it and pairing it with OTL and iFi Go Pods overall for TWS amongst collection
Trifecta & C9
RAAL 1995 Immanis
Perpetua
PMG APX SE
Radon6
Mass Kobo-465 Amplifier
VE10
With my A3t (w/ stock cable & Sony Xperia 1 V) and A4s (w/ PS TWS-A Bluetooth & Sony Xperia 1 V) ciems getting the most use on the go and at work these days, I'm fairly content with my daily go-to sets when I'm at work or out & about. No recent iem purchases were made earlier this year, yet I recently acquired my first tube headphone amplifier (Cayin HA-6A), new old stock tubes (2 x Tungsol 6550 solid black plate NOS tubes w/ top side triple getters & 2 x Amperex 7316 NOS tubes), desktop DAC (Cayin iDAC-8) and a new set of headphones (ZMF Verite closed-back headphones). Reading through different posts on threads & forums on finding & buying the right pair of new old stock tubes (in terms of synergy), interconnect & hp cables has got me to a 'settling' point where I feel no further desire to upgrade my headphone setup in the next 5 years or so (w/ exception of changing out new old stock tubes with different pairs). I'm quite happy & more than satisfied with what I have so far, and until the next big change/breakthrough in iem & headphone tech happens, I'll make my next big purchase when that time comes around. =)
Hearing the Susvara
Penon Rival
Probably Rhapsodio Supreme V3
Finally picking up the Campfire Trifecta :)
APX SE
Effect Audio Beyond, Forté Ears Ambition & Macbeth, Eletech Euclid, Vision Ears EXT MKII, UM Maven II
Trifecta (love/hate)
Just really grateful for meeting so many great and kind people throughout the years.
CFA Supermoon
Quloos
Trifecta
Bonneville
Dita Perpetua
taylor swift
Campfire Moon Rovers
Astrolith
Sub $200 budget iems
None
NYC CanJam
mason fs, unexpectedly great sounding without attempting to grab your attention
ibasso 3T-154
PMG Audio Apx SE
Aful Cantor
The treble on the Annihilator
Todd's Wilsons
Audio Technica Narukami Demo at NYC
AK x EE Novus
Experiencing bone conduction IEMs
Sony wm1z
Eminent Ears Ruby
discovering alot of new music😊
Westone Mach 80 has surprised me on many levels. Completely neutral sound signature with all BA can be fun. Isolation is perfect. The IEM and cable are super rugged and durable.
Alpha Omega Omega
Rockna Wavedream-Envy-Immanis, WM1ZM2-Tsunaragi-APX SE / Fei Wan
PMG Apx SE, MA Alter Ego
Becoming a member of the trade.
APX SE
LP6 Ti199
Cayin C9II
Astrolith
Falling in love with transducers that I thought I did not like as much.
HS2000MX Mk3
Questyle CMA18P
UM Maven II
Canjam London - Subtonic Storm
Cayin n7, EE raven, CA trifecta
PMG Audio Apx.
Bonneville
The yen is weakening
VE EXT MKII, QDC Emperor
PMG Audio APX SE
Not needing to upgrade any of my already awesome gear
Dunu DaVinci
Annihilator 23
NA
Trying out Elysian and FiR flagships
634ears Miroak-II Kalimantan
Cp74e
Alter Ego
taylor swift
RAAL Immanis
Meeting local audiophile friends
D16
Mostly being content with what I have
Finally acquire the ultimate treblehead IEM & new end-game - Annihilator 2021. Also, able to demo the CP622B and love it too, would save for it next.
Buying and waiting for APX SE
Watercooler tours
Released in 2024: Campfire Audio Astrolith
Ifi Kensei
PW headphone filter.
Embracing tip rolling
Subtonic Storm
AFUL Cantor
The bass quality and impact of the PMG APX SE
taylor swift
VE10 & iBasso DC Elite
ZMF Caldera
Thieaudio Origin
VE X
Maven
Thanks to everyone who participated!
Sep 13, 2024 at 11:28 PM Post #95,264 of 107,364
Desert Island IEMs
PMG APX/SE x27
Fir Rn6 x18
Subtonic STORM x15
Fir Xe6 x13
Vision Ears VEX x12
Sony IER Z1R x10
Dita Perpetua x7
64 Audio u/a12t x7
AK/VE Aura x6
Canpur CP622b x4
Vision Ears EXT x4
Sennheiser IE900 x4
AK/EE Novus x4
Empire Ears Odin x4
FitEar DC TI x3
Noble Audio Onyx x3
64 Audio U4s x3
North America - 50
Western Europe - 30
East Asia - 6
Australia - 4
South Asia - 2
Eastern Europe - 2
South America - 1
Africa - 1
RS8, n30le
Hiby R4
Astell&Kern SP2000
Shanling M6 Ultra
Wm1zm2, rs8, n30le
N30LE, N7
Sony WM1ZM2.
RS8, R8 II, WM1Z
A&K 3000, Hiby RS8
E7, P6Pro, PAW6P
IBasso DX320 MAX Ti
Dx300 max ss
Lotoo Mjolnir
M15s
RS8, N8ii, AR-M2
Hiby RS8 II
E7, WM1Z, SP3000T
Hiby R6III
RS8, 1Z/1ZM2
N30LE
Hiby r8 ii
Wm1z and calyxM
N30LE
WM1Z, W1AM2
WM1Z
Ibasso D320MAX TI
HiBy RS6, Sony wm1z
Sp3000
iBasso DX260, LPGT
DX260
AK SE300, M9+
FiiO M15S
E7; DMP-Z1; M9+
LPGT
RS8, M9+
AK SP3KT
COWON PL , CAYIN N7
RS8
Lotoo LPGT
HiBy RS8 II
LP 6 Ti
Sony wmzm2
N/A
SE200
Lotoo paw 6000
Sony WM1ZM2
Shanling M8
Hiby r8ii
Dx300MaxSS
N30LE AP
RS6, RS8, Mojo 2
D16?
Ibasso DX320 max ti
Hiby R8ii
Cayin N7
1AM2, RS8 SP3000.
Sony WM1Z
iBasso DX300
Hiby R3, Hiby RS8
N/A
P6Pro
In your own words:
Apx Se
PMG APX SE
Hiby R4
Xenon 6
A&K SP3000
Solid wood Sharona
L&P E7 EE
Trifecta & C9
RAAL 1995 Immanis
Perpetua
PMG APX SE
Radon6
VE10
Hearing the Susvara
Penon Rival
APX SE
CFA Supermoon
Quloos
Trifecta
Bonneville
Dita Perpetua
taylor swift
Astrolith
None
NYC CanJam
ibasso 3T-154
PMG Audio Apx SE
Aful Cantor
Todd's Wilsons
AK x EE Novus
Sony wm1z
Eminent Ears Ruby
Alpha Omega Omega
APX SE
LP6 Ti199
Cayin C9II
Astrolith
HS2000MX Mk3
Questyle CMA18P
UM Maven II
PMG Audio Apx.
Bonneville
PMG Audio APX SE
Dunu DaVinci
Annihilator 23
NA
Cp74e
Alter Ego
taylor swift
RAAL Immanis
D16
Watercooler tours
Ifi Kensei
Subtonic Storm
AFUL Cantor
taylor swift
ZMF Caldera
Thieaudio Origin
VE X
Maven
Nothing better than a Watercooler poll to establish the best of the best in iems ❤️!
Sep 14, 2024 at 3:45 AM Post #95,265 of 107,364
Desert Island IEMs
PMG APX/SE x27
Fir Rn6 x18
Subtonic STORM x15
Fir Xe6 x13
Vision Ears VEX x12
Sony IER Z1R x10
Dita Perpetua x7
64 Audio u/a12t x7
AK/VE Aura x6
Canpur CP622b x4
Vision Ears EXT x4
Sennheiser IE900 x4
AK/EE Novus x4
Empire Ears Odin x4
FitEar DC TI x3
Noble Audio Onyx x3
64 Audio U4s x3
North America - 50
Western Europe - 30
East Asia - 6
Australia - 4
South Asia - 2
Eastern Europe - 2
South America - 1
Africa - 1
RS8, n30le
Hiby R4
Astell&Kern SP2000
Shanling M6 Ultra
Wm1zm2, rs8, n30le
N30LE, N7
Sony WM1ZM2.
RS8, R8 II, WM1Z
A&K 3000, Hiby RS8
E7, P6Pro, PAW6P
IBasso DX320 MAX Ti
Dx300 max ss
Lotoo Mjolnir
M15s
RS8, N8ii, AR-M2
Hiby RS8 II
E7, WM1Z, SP3000T
Hiby R6III
RS8, 1Z/1ZM2
N30LE
Hiby r8 ii
Wm1z and calyxM
N30LE
WM1Z, W1AM2
WM1Z
Ibasso D320MAX TI
HiBy RS6, Sony wm1z
Sp3000
iBasso DX260, LPGT
DX260
AK SE300, M9+
FiiO M15S
E7; DMP-Z1; M9+
LPGT
RS8, M9+
AK SP3KT
COWON PL , CAYIN N7
RS8
Lotoo LPGT
HiBy RS8 II
LP 6 Ti
Sony wmzm2
N/A
SE200
Lotoo paw 6000
Sony WM1ZM2
Shanling M8
Hiby r8ii
Dx300MaxSS
N30LE AP
RS6, RS8, Mojo 2
D16?
Ibasso DX320 max ti
Hiby R8ii
Cayin N7
1AM2, RS8 SP3000.
Sony WM1Z
iBasso DX300
Hiby R3, Hiby RS8
N/A
P6Pro
In your own words:
Apx Se
PMG APX SE
Hiby R4
Xenon 6
A&K SP3000
Solid wood Sharona
L&P E7 EE
Trifecta & C9
RAAL 1995 Immanis
Perpetua
PMG APX SE
Radon6
VE10
Hearing the Susvara
Penon Rival
APX SE
CFA Supermoon
Quloos
Trifecta
Bonneville
Dita Perpetua
taylor swift
Astrolith
None
NYC CanJam
ibasso 3T-154
PMG Audio Apx SE
Aful Cantor
Todd's Wilsons
AK x EE Novus
Sony wm1z
Eminent Ears Ruby
Alpha Omega Omega
APX SE
LP6 Ti199
Cayin C9II
Astrolith
HS2000MX Mk3
Questyle CMA18P
UM Maven II
PMG Audio Apx.
Bonneville
PMG Audio APX SE
Dunu DaVinci
Annihilator 23
NA
Cp74e
Alter Ego
taylor swift
RAAL Immanis
D16
Watercooler tours
Ifi Kensei
Subtonic Storm
AFUL Cantor
taylor swift
ZMF Caldera
Thieaudio Origin
VE X
Maven
Audio Highlight of 2023
3 x Taylor Swift? 🧐🤔
