Originally Posted by The-One
Hey Ray:
I've just bought the E500 I'm looking for an amp to match. Hope the Tomahawk will fit nicely with the Shures.
Count me in for Xmas!
In the meantime, since the E500 is so sensitive, the hiss is driving me mad.
The Tomahawk headphone amp works great with the E500, as it was one of the phones used to design the amp.
You should hear no hiss what so ever.
Many are asking if the Tomahawk can drive other headphones properly. I do not want to go beyound what the Tomahawk can do, I only comment on what the amp was designed for plus being so tiny with battery life that is very impressive.
These were the phones that I used to develop the Tomahawk IEM amp:
IEMs: Shure E500, Shure E5C, Shure 4C, UE-10 & ETYs.
Pro-headphones: R-10, HD600, PS-1 & HF-1.
The Tomahawk has the guts to drive IEM with absolute control, while gain is set at low, gain of "1".
With gain set at high, gain of "3", it is capable to give you the satisfaction that you are looking for to drive your low impedance headphones with a great sound quality that you would demand from your source.
Meridian G-08 was used to develope the sound of the Tomahawk, the final A/B between the input & output of the amp were so close that it was hard to tell the difference.
Thanks.
Ray Samuels
