xnor
- May 28, 2009
1) Well, what about using the Olive/Welti target curve and calculating the "distance" from it for each headphone?
Something like the HD800 would never score an A for me personally due to the treble peaks, but with some EQing would probably be an A-rated dynamic headphone due to the low distortion, extension at the frequency extremes ...
2) I would do the same with distortion, like 3% at 20 Hz wouldn't matter much, but 3% at 1 kHz would result in a severe score penalty.
3) Think about the distortion numbers in general.
4) Smoothness of frequency response should be calculated like 1) from raw data.
5) A dip at ~100 Hz may only be cosmetic if distortion is still low. Easy to EQ. So the score penalty should be a lot smaller.
6) Who cares about the impedance curves?
7) Channel balance: again, scored by calculating it over the whole frequency range.
8) (Semi)open: shouldn't matter at all. Different strokes for different folks or applications.
9) Treat every headphone equally. Ignore price and marketing. If a 100$ headphone beats a 1400$ one so be it.
Score for each category could be from 0.0 (complete and utter failure) to 1.0. Different categories may need different weighting for the final summed score.
