plonter
- Oct 18, 2008
Please confirm the Modi2 can do 24/176.4.
Modi 2 Uber: 16/44.1 to 24/192 via USB. 16/44.1 to 24/192 via Toslink* and Coax.
*Note: many optical transmitters cannot output 24/176 and 24/192 reliably
You could look this up on their web page. Did you try?
I am looking at the USB only version of the modi. And yes I looked at their website, And I just want to be sure that "to 24/192" also includes 176.4.. It is not mentioned specifically.
it needs to be plugged into the wall. The linear power supply runs everything but the USB input.
did you get magni 2 uber too? i think if you experience no issue from your PC, amp probably gives you discernable improvement than dac
except if you have noisy dac/amp from your motherboard, then better dac will help.
if you're using onboard sound, you'll almost definitely hear a difference. onboard sound sucks 95/100 times.
Shoot them an email, they respond very quickly. NIck is brief and right to the point.
Wow! that was quick.. just email them and got a response in 5 seconds!
It (the modi 2) does support 176.4. Right now it is a candidate for a sidegrade (or upgrade) to my Dragonfly which unfortunately can't handle above 96Khz.
I tell you, that Modi 2 Uber looks to be an incredible bargain. I would definitely spend the extra $50 on the Uber.
I actually consider replacing a V-DAC II with Modi 2 Uber in my "big" Hi-Fi system. Wonder how these two would compare.
Do you like your Bifrost?
I used to have the V-DAC (the I version). The Bifrost was for me a subtle but important improvement. When I sent Bifrost back later for the Uber upgrade, I put the VDAC back in the system for those 2 weeks. It was fine, but had a little bit of a sharp edge to the sound that I didn't care for - and was happy and relieved when Uberfrost came back in.I love my Bifrost. And there's nothing wrong with V-DAC II. In fact, I've tried replacing it with Bifrost just for fun and couldn't tell any difference. As I said I'm more tempted with a switchable input. And yes, I just need more Schiit.
Something tells me I wouldn't hear any difference, but I need switchable inputs and I have an urge to buy some more Schiit.
